about Hondata S300
Old Oct 23, 2005 | 06:55 PM
valentino08's Avatar
Default about Hondata S300
i got a 97 ITR & i am planning to convert to S300, just wonder is that i have to change the distribuitor as well?? what ECU i should get?? i did some reserach but it is really confusing me??? anyone did that before??? just wanna to make sure all the things before i buy it!
thanks
cheers
Karsoon
Old Oct 23, 2005 | 07:00 PM
blkitr's Avatar
» Search Results
Your search for S300 returned 40 results.
Old Oct 23, 2005 | 07:05 PM
ZygSpeed's Avatar
Default Re: about Hondata S300 (valentino08)
Speak to your local Hondata dealer or tuner.
Otherwise e-mail Hondata itself or check their web site (http://www.hondata.com)
Old Oct 23, 2005 | 07:07 PM
John Z's Avatar
dont quote me but i THINK all u need is a OBD 1 ecu with adaptor harness and you should be set... (idk?)
Old Oct 23, 2005 | 07:13 PM
b19coupe's Avatar
OBD2 to OBD1 conversion harness. P28 ECU for the Hondata. Tuner.
Old Oct 23, 2005 | 07:22 PM
Default Re: about Hondata S300 (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">OBD2 to OBD1 conversion harness. P28 ECU for the Hondata. Tuner.</TD></TR></TABLE>
thanks for ur infromations but i found on Hondata it wrote P28,P30,P72,P61 ECUs configured to run non-VTEC, so what does it means???
Old Oct 23, 2005 | 07:27 PM
b19coupe's Avatar
P28's are cheap and plentiful. You can use a P30, P72 etc.
Old Oct 23, 2005 | 07:39 PM
how come it will say wrote P28,P30,P72,P61 ECUs configured to run non-VTEC????
just want to confirm one more time.... (sorry about that) after confirmed i am going to get now thanks
Old Oct 23, 2005 | 07:48 PM
rhd's Avatar
rhd
any obd1 auto/non-vtec ecu other than a p05 will work
but there's no point in wasting money on an S300.... ostrich and crome will work fine, and have less issues than s300, oh, and be cheaper
Old Oct 24, 2005 | 07:30 AM
98 Spec R's Avatar
Default Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">but there's no point in wasting money on an S300.... ostrich and crome will work fine, and have less issues than s300 </TD></TR></TABLE>
I havent had any problems with my S300! I love it
Old Oct 24, 2005 | 10:53 AM
Stinkycheezmonky's Avatar
Suspetise...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by valentino08 &raquo;</TD></TR><TR><TD CLASS="quote">how come it will say wrote P28,P30,P72,P61 ECUs configured to run non-VTEC????
just want to confirm one more time.... (sorry about that) after confirmed i am going to get now thanks</TD></TR></TABLE>
Those codes are each for a different Honda ECU, with each one (P28 is one, P30 is another, etc.) representing a different non-VTEC ECU. Just call up Hondata, it sounds like you need some very specific instructions.
Old Oct 24, 2005 | 12:12 PM
cltitus's Avatar
i was runnign a s300 with all stock motor was running fine but runs better if you change the ignition system later on im mods
Old Oct 24, 2005 | 01:25 PM
done's Avatar
Default Re: (Yaz)
Yes all you need a obd1 ecu with 0bd2 to obd1 harness..
p28 is the most popluar.
Old Oct 24, 2005 | 03:35 PM
thanks all of u here finally Hondata replied me they advised me to use P30, P61 or P72
Old Oct 24, 2005 | 03:48 PM
hYpE-R-29's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by valentino08 &raquo;</TD></TR><TR><TD CLASS="quote">thanks all of u here finally Hondata replied me they advised me to use P30, P61 or P72 </TD></TR></TABLE>
p28 is better..doesnt search for the knock sensor..get that
Old Oct 24, 2005 | 04:13 PM
Default Re: about Hondata S300 (hYpE-R-29)
i found a P28 & the guy told me it came out from an auto JDM EJ couple SOHC VTEC but the ECU is in rectangle, do u guys think it can fit my car??? (need answer as soon as possible) thanks
Old Oct 24, 2005 | 05:18 PM
done's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by valentino08 &raquo;</TD></TR><TR><TD CLASS="quote">i found a P28 & the guy told me it came out from an auto JDM EJ couple SOHC VTEC but the ECU is in rectangle, do u guys think it can fit my car??? (need answer as soon as possible) thanks</TD></TR></TABLE>
s300 will not work with a jdm ecu
Old Oct 24, 2005 | 05:54 PM
hYpE-R-29's Avatar
just get a regular p28 from a civic si, your running hondata on it anyways
Old Oct 24, 2005 | 05:59 PM
rhd's Avatar
rhd
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hYpE-R-29 &raquo;</TD></TR><TR><TD CLASS="quote">
p28 is better..doesnt search for the knock sensor..get that</TD></TR></TABLE>
you can turn that off with any chipped ecu
p28 usually cost a expletive ton more than a non-vtec/auto ecu...whihc you can someitmes get for FREE
Old Oct 24, 2005 | 06:49 PM
hYpE-R-29's Avatar
Default Re: about Hondata S300 (rhd)
p28 usually cost a expletive ton more than a non-vtec/auto ecu...whihc you can someitmes get for FREE</TD></TR></TABLE>
p28 is about $75 in good condition
Old Oct 24, 2005 | 09:43 PM
p28 is about $75 in good condition</TD></TR></TABLE>
actually i am in New Zealand, real hard to get USDM ECU at here anyone here know any links or how can i buy that ECU from???
Old Oct 25, 2005 | 09:20 AM
98 Spec R's Avatar
actually i am in New Zealand, real hard to get USDM ECU at here anyone here know any links or how can i buy that ECU from??? </TD></TR></TABLE>
Locashracing is an authorized Hondata Dealer. He can get you just a P28 ECU or the entire S300 system.
http://www.locashracing.com
Good Luck!
Old Oct 25, 2005 | 09:43 AM
splitime's Avatar
Default Re: (rhd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rhd &raquo;</TD></TR><TR><TD CLASS="quote">any obd1 auto/non-vtec ecu other than a p05 will work
but there's no point in wasting money on an S300.... ostrich and crome will work fine, and have less issues than s300, oh, and be cheaper</TD></TR></TABLE>
I agree on the 2nd part. But you CAN use a p05, it just requires one more part soldered in to convert it to 4wire o2.
Old Oct 25, 2005 | 10:18 AM
Edward's Avatar
Sorry. I have another question.
Do i need to use hondatat dealer to tune the S300? Or any tuner also can tune my car with S300.
Old Oct 25, 2005 | 10:31 AM
98 Spec R's Avatar
Default Re: about Hondata S300 (Edward)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Edward &raquo;</TD></TR><TR><TD CLASS="quote">Do i need to use hondatat dealer to tune the S300? Or any tuner also can tune my car with S300. </TD></TR></TABLE>
You can tune it yourself, if you know what you are doing. The S300 downloads the ROM through a USB cable so changes can be made and saved on your ECU, almost instantly. The tuner does not have to be a Hondata dealer if they understand how the system works.
