ok toss me ideas....car cranks "when it wants to"
Old Oct 23, 2005 | 06:11 PM
Sleepy_Red_hatch's Avatar
Default ok toss me ideas....car cranks "when it wants to"
ok so i sit in my car, put the key into the ignition, i turn it all the way and i hear the fuel pump prime then silence.....hold it there.....hold it there....hold it there....(underdash)CLICK(/underdash) then it starts...sometimes takes 5 seconds, sometimes works instantly, someitmes takes up to 5 mins....
so what? main relay?? but the fuel pump primes...? im at a loss, what can i do short of trying a new main relay?
Old Oct 23, 2005 | 06:15 PM
PyroProblem's Avatar
Default Re: ok toss me ideas....car cranks "when it wants to" (Sleepy_Red_hatch)
possible bad ignition switch or a starter relay...
Also maybe a bad clutch switch...
Old Oct 23, 2005 | 06:17 PM
JDMKid71's Avatar
Default Re: ok toss me ideas....car cranks "when it wants to" (PyroProblem)
Yep i was thinking clutch switch... is it a auto or manual?
Old Oct 23, 2005 | 06:18 PM
Project_DX's Avatar
i don't know....thats something...
it could be your main relay, but another thing that just happed to pop in my head was to check your ground to your starter...maybe it's lose and has a bad connection...then dep. on how your car is sitting it's worse then others
just a thought
Old Oct 23, 2005 | 09:25 PM
Default Re: ok toss me ideas....car cranks "when it wants to" (Project_DX)
manual, and the clutch thing did come to mind, where is this clutch switch?
Old Oct 23, 2005 | 09:57 PM
FalkenSiR's Avatar
top of the clutch pedal assy. one wire coming in, one wire coming out. Pull the plug and bypass the switch.
Old Oct 24, 2005 | 04:09 AM
Default Re: ok toss me ideas....car cranks "when it wants to" (fast88std)
bypass it? u mean with another switch right?
Old Oct 24, 2005 | 06:38 PM
up.
Old Oct 24, 2005 | 06:45 PM
Luserkid's Avatar
Sounds like a bad ground.
Old Oct 24, 2005 | 07:18 PM
nhlfan's Avatar
starter relay.
Old Oct 24, 2005 | 07:23 PM
civic_driver's Avatar
bad ground/connection or discharged battery
make sure your battery is good, and clean up and tighten those battery terminals
Old Oct 24, 2005 | 07:27 PM
NonovUrbizniz's Avatar
Loved
Default Re:
I'd bet it's your main relay... It serves as the starter relay.
Old Oct 24, 2005 | 07:48 PM
Default Re: Re: (NonovUrbizniz)
i think teh main relay should be ok since the fuel pump primes....how do i test teh clutch switch? and how much is a new one?
Old Oct 25, 2005 | 05:03 PM
Loved
Default Re: Re: (Sleepy_Red_hatch)
It's just a 2 wire momentary switch... it should be pretty straight forward...
If you have a test light just test both wires with it not depressed and then both with it depressed... if they're the same both ways then it's busted.
I'd lean more towards a starter solonoid or relay... doesn't sound like a switch problem.
Old Oct 25, 2005 | 08:11 PM
b16a2delsol's Avatar
My Del Sol Was doing the exact same thing for awhile and it turned out to be a wire plug was loose ( the closest one to the clutch pedal) just make sure everything down there has been plugged in correctly.. if they're all good then Do all the above ^^
Old Oct 25, 2005 | 09:13 PM
Bartman201's Avatar
ok before you start looking for any parts check the ground cable that goes to the trany. i just had the same problem.
here https://honda-tech.com/zerothread?id=1410872
alex1320
26
May 27, 2014 07:08 AM
magicmyst98
14
Sep 2, 2013 12:06 PM
EternalSessions
Apr 14, 2013 10:52 AM
osbunjosh
Apr 29, 2012 08:27 AM
skata89
May 21, 2006 06:44 AM
