Getting my maintainance done finally. Anything else I should have them do?
Old Oct 23, 2005 | 05:32 PM
The Droogan Leader's Avatar
Now with ultra-violence!
Default Getting my maintainance done finally. Anything else I should have them do?
I'm finally taking the Shin-tegra to the mechanic to get a new timing belt installed. Anything else I should have him take a look at?
Old Oct 23, 2005 | 05:36 PM
Racermech's Avatar
Default Re: Getting my maintainance done finally. Anything else I should have them do? (Shin-tegra)
water pump and tensioner. While he is there replace all of the other belts.
Have you done any other maintainance?? If not, and you are not going to do it have him do all of the regualr stuff, plugs,wires,cap,rotos,fuel filter, tranny fluid, oil change.
Old Oct 23, 2005 | 05:43 PM
Default Re: Getting my maintainance done finally. Anything else I should have them do? (Racermech)
Sounds good. I'll skip on the oil and MTF change seeing as how I just did those myself recently.
Old Oct 23, 2005 | 07:04 PM
.Kevin.'s Avatar
u should probable be able to do plugs wires and cap and rotor on your own, if u have basic tools i think you should try the t belt youself, theres many good write ups on here to help out, it will save you about 200$ and give you some learning grounds...even if you dont have all the tools you could take that 200$ in labor and use it to get the tools
Snowwhitecoupe
Oct 21, 2011 05:13 PM
matryx
Jul 16, 2007 04:45 PM
DC2_ITR
Apr 26, 2007 07:52 PM
Seks
Aug 9, 2004 12:55 PM
who00knows
Jul 31, 2003 05:39 AM
