workin on a b16 everyone give there thoughts
hey guys im new in here so i figure ill tell you a lil about what i have that im building and get your all input. any one have suggestions
Ive got a b16a ok ive got
titanim springs and retainers
stainless steel valves
3 angle valve job
crawer stage 3 drag cams
skunk 2 adj. cam gears
JE Piston 9:1comp
eagle rods H-beam
bord to a 2.0
aebs intake manifold
aem fuel rail
aem fuel presure regulater
JE throttle body
i have a greedy turbo kit pushing 10 pounds
all piping and intercooler
i have the zex kit 75 shot
i wanted to post pics on here but it will not let me because i just join or whatever if u wanna see pics i can e-mail them to you
Modified by boostedhatch85 at 7:55 PM 10/23/2005
3 angle valve job
JE Piston 9:1comp
eagle rods H-beam
bord to a 2.0
aem fuel rail
JE throttle body
i bought the block and i got screwed and i had to make it work and thats what it was bored out to be. The stock bored on a b16 is 3.19 and when i got this b16 it is 3.31. i hope everything will work togeather well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedhatch85 »</TD></TR><TR><TD CLASS="quote">i bought the block and i got screwed and i had to make it work and thats what it was bored out to be. The stock bored on a b16 is 3.19 and when i got this b16 it is 3.31. i hope everything will work togeather well</TD></TR></TABLE>
If it's not sleeved that motor will not take boost for one second, period.
Otherwise, an 84mm bored out B16 works out to a pinch over 1.7 litres, not 2.0 litres.
cool deal i had a stock b16 boosted for 3 months didnt run bad until it blow all to hell. Noone around where im from is into imports mostly ****** musle cars it sucks. But would b20 pistons work in this block sence it has the same bore.
boostedhatch85
Oct 23, 2005 06:52 PM
nonoy93cvc
11
Oct 8, 2005 09:08 AM
EG-cellent
12
Aug 31, 2004 04:16 AM
