Need help from anyone with a megan adjustable cam gear.
Old Oct 23, 2005 | 04:26 PM
NACvicSi's Avatar
Default Need help from anyone with a megan adjustable cam gear.
I bought a megan adjustable cam gear, but it has no instructions. I can't find any marks on it to indicate where TDC is at like on the stock gear. Where is this located or is there one on it at all?
Old Nov 19, 2005 | 08:10 AM
DelSolDon's Avatar
Default Re: Need help from anyone with a megan adjustable cam gear. (NACvicSi)
bump for an answer because I have one on the way.
Old Nov 19, 2005 | 08:18 AM
STREETWERKZ's Avatar
Default Re: Need help from anyone with a megan adjustable cam gear. (DelSolDon)
ebay ownz again.
Old Nov 19, 2005 | 08:32 AM
DelSolDon's Avatar
Default Re: Need help from anyone with a megan adjustable cam gear. (STREETWERKZ)
yea, thanks for the help
i'm sure i can figure it out once it gets here by lining it up with the OEM cam gear. ebay is a great place if you know what you are looking for and you know what is junk and what is decent. i have bought many things from there with no problem. and no TDC marking is not ebay's fault, it is megan's fault.
Old Nov 19, 2005 | 08:39 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon &raquo;</TD></TR><TR><TD CLASS="quote">ebay is a great place if you know what you are looking for and you know what is junk and what is decent. i have bought many things from there with no problem. and no TDC marking is not ebay's fault, it is megan's fault. </TD></TR></TABLE>
you get what you pay for.......
only place i see megan racing is ebay...... so there ya go.
Old Nov 19, 2005 | 09:38 AM
Suck my DX's Avatar
when it comes to critical engine parts why would u cheap out to save like 20 bux...
why not just pay a little extra for a quality piece that will be more precise and last a lot longer.
Old Nov 20, 2005 | 04:47 AM
DelSolDon's Avatar
Default Re: Need help from anyone with a megan adjustable cam gear. (Suck my DX)
because I've seen both AEM and Golden Eagle (which are supposed to be decent) cam gears busted. the megan cam gear looks like it doesn't have a weakness issue like those. the others were failing was right around where the camshaft goes thru, and as you can see in this pic, it is one solid piece.
the others seemed to be breaking because the spokes coming out from the center were too thin and came too far in to the center. even if for the rare instance the spokes would break on this one, the 6 bolts would still hold it in place enough to keep it from blowing up your valvetrain.
to each your own, if you like paying extra money for a name, even though it is inferior, go ahead.
Old Nov 20, 2005 | 05:32 AM
Autoworks's Avatar
TDC is exactly where the cam tooth goes, as far as putting it onto the cam. Are you saying that there are no markings on the gear for making adjustments? If so, I wouldn't put it on.
Old Nov 22, 2005 | 02:36 PM
DelSolDon's Avatar
Default Re: Need help from anyone with a megan adjustable cam gear. (Autoworks)
just got mine, it does have a TDC mark and has markings for adjustments. seems like a solid piece. only thing is that it requires a woodruff key to go in the notch of the cam. the stock cam gear has the key built into the gear. does anyone know what size key to use?
edit: after some searching, it looks like i'm just gonna take it to the parts store and see which fits.
Modified by DelSolDon at 7:09 PM 11/22/2005
Old Nov 22, 2005 | 03:29 PM
Autoworks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolDon &raquo;</TD></TR><TR><TD CLASS="quote">just got mine, it does have a TDC mark and has markings for adjustments. seems like a solid piece. only thing is that it requires a woodruff key to go in the notch of the cam. the stock cam gear has the key built into the gear. does anyone know what size key to use?
Modified by DelSolDon at 7:09 PM 11/22/2005</TD></TR></TABLE>
It's around $6 from Honda, get OE
Old Nov 22, 2005 | 04:44 PM
DelSolDon's Avatar
actually i contacted the seller from ebay (built4race) and he is sending me one at no charge
Cashieboi
10
Feb 4, 2007 06:06 PM
1boostedcivic
Jun 4, 2005 07:08 PM
