Suspension & Brakes Theory, alignment, spring rates....
alignment problem
Old Oct 23, 2005 | 04:17 PM
jweller's Avatar
Default alignment problem
ok I just installed my ingalls rear camber kit. I have not had it professionally aligned yet, I've got an appointment later this week.
anyway, before I installed the kit, the car drove pretty much straight. pulled slightly to the right but not bad. I put the kit on, set the camber arms up just slightly shorter than the stock pieces and didn't tough the toe adjustment. took the car on a quick test drive around the neighborhood and something is waaayyyy outta whack. car pulls HARD to the right and the steering wheel is cocked to the right maybe 20 degrees even when you are driving straight. I mean its obviously way off. nothing was touched on the front end at all. I'm guessing that my rear toe is really screwed up but it's nothing you can obviously see. any advice on what to start looking at? I've got to drive it for a couple days so i'd like to get it back close at least.
kodythejdmkid
Suspension & Brakes
24
Jul 8, 2012 11:38 PM
Ross2852
Jul 28, 2005 06:06 PM
budget
Apr 13, 2005 03:54 AM
dacaveman
Nov 29, 2003 03:18 PM
