Fuel Cut-Off of a ITR 2000 USDM ?
Old Oct 23, 2005 | 04:11 PM
G0dzArmy's Avatar
Default Fuel Cut-Off of a ITR 2000 USDM ?
Hi.
I need to know the STOCK Fuel Cut-Off of a Integra Type R UDSM that came from the DEALER, I don't wanna Hear Chiped ECU. Some Stupid fools on Montrealracing.com are Saying it's 9100 to 9200 RPM. In fact I had my self a EG with a B18C5 Engine and it was like 8500 RPM.
Who's right?
Old Oct 23, 2005 | 04:22 PM
MOVE OVER's Avatar
Default Re: Fuel Cut-Off of a ITR 2000 USDM ? (G0dzArmy)
it is in the search... but fuel cut off is at 8500 RPM.
However my stock guage is pretty inaccurate and indicates over 9 grand.
Old Oct 23, 2005 | 04:44 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Fuel Cut-Off of a ITR 2000 USDM ? (ITR 1102)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 1102 &raquo;</TD></TR><TR><TD CLASS="quote">it is in the search... but fuel cut off is at 8500 RPM.
However my stock guage is pretty inaccurate and indicates over 9 grand.</TD></TR></TABLE>
Yup. So it depends on whether they're asking what the tach reads when you hit the rev limiter, or what the actual engine revs are when you hit the rev limiter. Both numbers are correct, depending on what the question is.
Old Oct 23, 2005 | 05:14 PM
G0dzArmy's Avatar
Default Re: Fuel Cut-Off of a ITR 2000 USDM ? (nsxtasy)
Alright I had a EG CX 93 so i didn't have a tach in the cluster, But a have a monster tach with a shift light, and maybe it was more accurate, cause it was right on the 8.5k bar.
has anyone try with a aftermarket tach in a ITR... and compare both RPM meter ?
Old Oct 24, 2005 | 04:39 AM
Black R's Avatar
25 Year Member
the stock itr tach is off by ~500 rpm in the upper portion...
stock rev limiter is 8600 that i've recorded with a vafc on many occations.
This looks like 9k indicated on the stock tach.
-hth
Old Oct 24, 2005 | 09:53 AM
ivicr's Avatar
my 00 itR hits at 9300... stock. i think its off
Old Oct 24, 2005 | 10:37 AM
Jon D's Avatar
Default Re: Fuel Cut-Off of a ITR 2000 USDM ? (ivicr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivicr &raquo;</TD></TR><TR><TD CLASS="quote">my 00 itR hits at 9300... stock. i think its off</TD></TR></TABLE>
whoa.... yeah thats off much furthen then most, unless you have some headwork done
Old Oct 24, 2005 | 03:44 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G0dzArmy &raquo;</TD></TR><TR><TD CLASS="quote">Hi.
Who's right? </TD></TR></TABLE>
well, technically they are right on 90% of the ITR's.
they were probably telling you what the fuel cut off would be indicated on the tach...in case you were the stupid fool, instead of them
Old Oct 24, 2005 | 04:22 PM
Stein's Avatar
Default Re: Fuel Cut-Off of a ITR 2000 USDM ? (255.255.255.255)
It's 8600rpm as has already been stated but your tach will read higher.
Old Oct 24, 2005 | 06:03 PM
The Tech-1's Avatar
Same here! Been there done that numerous times ive been to 9500 man..
geeman640
Honda Civic (2006 - 2015)
13
Oct 5, 2007 12:00 PM
IA95civicDX
13
Oct 25, 2005 05:10 PM
brett booth
Jul 17, 2004 10:20 AM
Dammit_Dan_954
Jun 4, 2004 02:20 PM
Tommy_Gunns
Jul 28, 2002 03:11 PM
