rod bearings
Apart from oem, what are good rod bearings for a stock b18b rod...my setup is p30 pistons, crower 404 cams and arp rod bolts and head studs???
Thanks!!
Thanks!!
I'm using acl bearings in my integra. Not my bearing of choice but they are working fine. I will always say clevite makes the best bearings around. Thats what I've always ran in my other cars. But for the most part as long as you're getting a decent brand you'll have no problems what so ever. Clevite, sealed power(michigan), acl, even OE etc. I've actually seen more people get spun bearings after a rebuild on OE bearings. It really depends on how clean the place is where it is done and how well it was put together. Thats so much more important than what brand you're using.
Feb 15, 2004 09:08 PM
