What Does A JDM D15B Motor Normally Rev. To, And Is 8K Safe?
From: Couple SW99 40 Cal. For Ya, Do Ya Really Want It.., NJ, U.S.A
Can someone answer a question for me. My cousin just picked up a 95 civic that he was told had a JDM D15B with VTEC SOHC (NOT USDM), so he says. It was running rough so he tuned it up and installed a GSR computer, and it's running great, although the VTEC isn't hooked up yet, so he has to still work on that. Anyway what Does a JDM D15B motor Normally Rev. To, and is 8K safe? Thanks. Sorry if this is the wrong place for this post, but I thought it would get answered faster here, and this is where I normally post. If this needs to be moved I understand. Thanks again!
does the d15b have the same redline as the other SOHC vtec motors?
i thought it was around 7200 redline.You my get an answer sooner in the Civic or CRX forums.good luck.
Modified by gunnis at 11:08 AM 10/23/2005
From: chillin in that city called queen creek, but homes the atl
i revved to 8 when i had a turbo on mine but w/o the turbo it stops making any power around 7500
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeterkm02 »</TD></TR><TR><TD CLASS="quote">he put a gsr ecu on a d15b?</TD></TR></TABLE>
Yes he did it seems to run fine.
So what would be the max rpm on a stock d15b motor, other than I/H/E he could get away with safely?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01PYTypeR#1140 »</TD></TR><TR><TD CLASS="quote">So what would be the max rpm on a stock d15b motor, other than I/H/E he could get away with safely?</TD></TR></TABLE>
How long would he like to keep that motor for?
What if he put the shift light at 7,200 rpm so that he would shift at about 74k by the time he reacts to the shift light? Could he get away with shifting between 72k and 75k?
Considering the engine falls on its face at about 6800rpm, I'd set the **** light there. Overrevving an engine for ***** and giggles is stupid: if you're not making power, don't force the issue. It's a D15B, it's not fast - nor will it be - regardless of how much you abuse it, JDM or not.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluracer »</TD></TR><TR><TD CLASS="quote">its true, it feels like **** After 7500. i ran around for about a year 1/2 shifting at 7500, no problems.</TD></TR></TABLE>
I'm set my rev limiter to 7,400 RPM.. I usually shift at 7k though.
i have a d15b in my 93 coupe and im runnin the p28 for now till i find a p08, but the redline is 7200..plus who cares if its not the fasted motor ,he didnt ask if it would be.
tell your friend to get a ecu asap becuase hes car can't be running to good w/ a check engine light w/ a ecu thats looking for iab's and a knock sensor
i was under the impression that the redline for a jdm d15b was 7800rpm....
personally i dont rev mine anywhere close for gas saving reasons, but i will generally shift at like 7 if i am really beating on it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chronicsinners »</TD></TR><TR><TD CLASS="quote">personally i dont rev mine anywhere close for gas saving reasons, but i will generally shift at like 7 if i am really beating on it</TD></TR></TABLE>
same here
same here
