tie-rod replacement part question!
Old Oct 23, 2005 | 06:07 AM
CleanHatch's Avatar
Default tie-rod replacement part question!
ok im a noob at replaceing the tie-rod, mines is clicking and i see the boot is cut up. what do i actualy replace? i know for sure the boot, but what else? circle 1, circle 2 or none of that?
Old Oct 23, 2005 | 07:21 AM
tvrsir's Avatar
Default Re: tie-rod replacement part question! (CleanHatch)
you only need number 2 if it's the outer tie rod.
Old Oct 23, 2005 | 02:05 PM
spoonracer84eg's Avatar
Default Re: tie-rod replacement part question! (tvrsir)
I agree...You could however go ahead and replace both the inner and outer tie rods but it would be easier to just do the outer tie rod. When you go to pull the outer tie rod off take the hardware off where it connects to the control arm and hit the bolt upwards with a dead blow hammer (metal hammer). Dont hit any new parts with a hammer due to the fact that you could tear up the threads.
Old Oct 23, 2005 | 02:13 PM
<p>
When you take the outer tie rod off dont forget to mark with a paint pin where it was on the inner tie rod or count the number of twist it takes to get it off. This will help prevent you from needing an alignment.
skipbudlong
31
May 6, 2010 10:21 AM
96 GSR-T
Nov 22, 2008 05:58 PM
VTECIntegra9
Suspension & Brakes
Aug 14, 2008 02:02 PM
DeDonDeRosa
Mar 1, 2007 11:59 AM
Timmah!!
Jul 21, 2003 03:46 PM
