96 hatch has no sway bars
Old Oct 22, 2005 | 09:46 PM
Slosc2's Avatar
Default 96 hatch has no sway bars
All I Need to know is what front and rear sway bars I can use on my hatch. Factory items preferrably. I understand I would have to use the same year/model LCA's?
Old Oct 22, 2005 | 10:00 PM
SOHC4life 96's Avatar
Default Re: 96 hatch has no sway bars (Slosc2)
You can use the front bar from really any car...... Just need the right endlinks. If you just want to bolt it up a 96-00 EX/99-00 Si front bar and the 99-00 Si rear bar. If you go anything bigger than the 99-00 Si rear bar you're going to need to get some kind of subframe reinforcement. The 96-00 Civics have a habbit of the subframe tearing away from the chassis. I suggest the A-spec Racing kit.
Old Oct 22, 2005 | 10:26 PM
Slosc2's Avatar
Default Re: 96 hatch has no sway bars (SOHC4life 96)
Im not looking for anything outrageous. For the front I was intending on using all factory EX equipment.
The rear I was more concerned with, I can get a 96 or 97 gsr rear bar pretty cheap. Im not sure what endlinks or mounts to use. Im gussing I could use the GSR endlinks and mounts.......this is where I need the help
Old Oct 22, 2005 | 10:37 PM
EK k kay's Avatar
A 99-00 si rear sway bar will bolt right up if it comes with endlinks, brackets, etc. Any front sway bar will require different front lca's and in some cases different shock forks. I think a GSR sway bar will work, but you need 99-00 si endlinks.
Old Oct 22, 2005 | 10:52 PM
Default Re: 96 hatch has no sway bars (EK k kay)
You can use the GSR endlinks, but you'll just have to use a nut and bolt to attach it rather than the threads already being on the link.
Old Oct 22, 2005 | 11:09 PM
teh MAARZ's Avatar
or u can get a beaks kit. they make hardware for ek
Old Oct 22, 2005 | 11:14 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">You can use the GSR endlinks, but you'll just have to use a nut and bolt to attach it rather than the threads already being on the link. </TD></TR></TABLE>
Ahh good stuff
Old Oct 23, 2005 | 07:24 AM
Slosc2's Avatar
cool, so just to make sure i got this correct......
Up front I can run all EX equipment. Swaybar, Endlinks, "C" Mounts, and LCA's.
Rear I can use GSR bar with GSR endlinks and GSR "C" mounts. stock LCA's.
Thanks for the help guys
96civic808
Apr 26, 2010 07:38 PM
Lightsped
12
Sep 2, 2009 08:36 AM
Santys EK
Aug 12, 2006 07:51 AM
Malakai
Jul 9, 2006 01:39 PM
wdskuk
Sep 21, 2003 08:17 PM
