B16? or SOHC V-TEC head on D-Series?
Old Mar 6, 2002 | 09:38 PM
LoooseGSR's Avatar
Default B16? or SOHC V-TEC head on D-Series?
What do you think? I know one is a lot cheaper than the other, but what about durability comparisons, and ease of install? Oh yeah and of course, POWER, I'm still relatively new to the CRX scene, I have a 89 Si, I just want some ideas for this summer and next fall, I might be going to Torrence to work for Honda, so since I'll be in the middle of the thing, just want some ideas...
Old Mar 6, 2002 | 10:02 PM
customx_'s Avatar
New User
Default Re: B16? or SOHC V-TEC head on D-Series? (PSUCRX)
b16a. enuf said.
Old Mar 7, 2002 | 04:53 AM
TypeR0207's Avatar
Default Re: B16? or SOHC V-TEC head on D-Series? (mindtrix)
Yeah, the head swap is much cheaper, but if you do it right, it STILL ends up costing a pretty penny.
Head gasket, head bolts, distributor, wiring, VTEC controller, timing belt, plugs, plug wires, and of course - the head.
You could end up spending $400-500 ........ for 125-130 hp and not as much potential.
[Modified by TypeR0207, 8:54 AM 3/7/2002]
Old Mar 7, 2002 | 05:15 AM
EP3_05's Avatar
B16 without a doubt. To do a head swap properly costs a good amount of money and if it isn't done correctly then it is going to give you problems down the road. If you were really set on the sohc vtec, i would just drop the whole longblock into your car.
Old Mar 7, 2002 | 08:01 AM
LoooseGSR's Avatar
Default Re: B16? or SOHC V-TEC head on D-Series? (91civic)
I still think the B16 is the best as well, i just saw a SOHC on ebay for like 150, with the VTEC solinoid, but my only other problem is I can't seem to find exact directions anywhere for what I need and what to do, any help is welcome, it won't be for a while,(money shortage) but when i do I'd like to be well versed in the process
Old Mar 7, 2002 | 08:02 AM
EL Vap133's Avatar
B16A!
Old Mar 7, 2002 | 08:07 AM
Mugen Dom's Avatar
Default Re: B16? or SOHC V-TEC head on D-Series? (Vap133)
if u can do it cheap like me find deals on **** do it. i mean i got the stuff for a non vtec head for under 100 like gaskets and such the head bolts are obscenely expensive 9 dollars a peice thats 90 bucks man if u have any hookups at honda use em now.... since we own a shop i get a discount so i get list prices... good luck if u decide to do the head swap.... u should be able to find the z6 motor cheaper than u could find the head and all teh aprts for.. people do swaps all the time in teh 5th gens i know of some that go for 300 with tranny
Old Mar 7, 2002 | 08:34 AM
marty's Avatar
Default Re: B16? or SOHC V-TEC head on D-Series? (jdmB18hatch)
Depends how your money flow goes.
Some like the high reving power B16 which can be costly when you do it right
But some like the torquey D16 which is cheaper but with less power.
whatever tickle da pickle man.
im a B cup man... some like D cups..
( wheres jason shakin his boobies? )
Old Mar 7, 2002 | 09:21 AM
Mugen Dom's Avatar
Default Re: B16? or SOHC V-TEC head on D-Series? (beatdown88hf)
wut about head bolts? reuse em? i thought about it but not to sure
Old Mar 7, 2002 | 09:30 AM
Mugen Dom's Avatar
try 9 each bro and u need 10
Old Mar 7, 2002 | 09:40 AM
TypeR0207's Avatar
Well, all of my **** was still original 120,000 mile stock, so I got new stuff.
2000 DX head - $85
Head gasket - $45
Head bolts - $100
Timing belt - $40
intake/exhaust manifold gaskets - $20 ????
intake/exhaust manifold nuts - $30 ????
Si intake manifold/tb/ECU/fuel set-up - $125 (thanks Phatwhippin!! )
Si distributor - $35
Wiring - $15
$515 plus other misc. bullshit .....
DAMN!!!! That is the first time I've added it up!!!! What a retard I was!!
Old Mar 7, 2002 | 09:45 AM
Mugen Dom's Avatar
Default Re: B16? or SOHC V-TEC head on D-Series? (TypeR0207)
damn rick heres mine
97 dx head same as rick $50
97 y8 head gasket $25
timing belt had one free
mpfi setup $5 (eat me hahah my boy said how much u give me i said 5 buck, now i have a d16a6 to freehahaha)
5 speed free
dizzy free
wiring free
muhahahahaha
so thats wut 80 bucks man i got a deal muchahahafuck 40 bucks for spark plug wires for the head rick u left that out to so 120 i love having a junkyard
Old Mar 7, 2002 | 12:29 PM
TypeR0207's Avatar
Yeah, I forgot plugs and wires in my list ....
But hey, I made out like a bandit because I got my B16 engine and tranny for $750!!
[Modified by TypeR0207, 4:29 PM 3/7/2002]
Old Mar 7, 2002 | 04:54 PM
cbrman's Avatar
Well the only thing I would say to take into account is the fact that for a b16 you will need to buy motor mounts. Arent they around 500 bucks for place/hasport mount kit??????
Anyways it's not going to be free whatever you do, so you have to decide how much you want to commit.
Davens had done the mini-me swap with a6 intake/exhaust manifold and a zdyne gold secu. IT was putting out just a few 1-3 hp more than a crx si at 108hp. Granted his torque numbers were better than the si. Would you like to spend 500 for a few horses and a little bit of torque?????
If you want to see the true potential of the mini-me, use the sohc vtec intake/exhaust manifolds as they were designed for that head. Also use the correct ecu. It will make all the difference.
PSUCRX....
I know what you mean, the honda hybrid how to for the sohc vtec swap is very limited in what they explain. I recently did the migration of a y8 into my crx, so I am going to come up with a how to that explains more than drop the motor in, wire it up and whala. By no means am I a honda expert, but I have done the complete swap installing the y8 motor, y8 intake manifold and y8 exhaust manifold. I installed the obd2 motor, with an obd1 ecu into a non-obd vehicle with limited knowledge of honda car engines. (bikes are another story )
Steven
Old Mar 8, 2002 | 06:30 PM
cbrman's Avatar
Default Re: B16? or SOHC V-TEC head on D-Series? (cbrman)
if you are interested there is a complete y8 swap with aem pulleys, aem intake, aem camgear etc. on ebay http://cgi.ebay.com/ebaymotors/ws/eb...515606&r=0&t=0
and another complete engine/tranny combo without a distributor. http://cgi.ebay.com/ebaymotors/ws/eb...611312&r=0&t=0
They are going for pretty cheap right now
Good luck
UniqueX707
Aug 26, 2012 11:52 AM
RICE POLICE SIP
20
Jun 13, 2006 07:22 PM
itsmebeaner1987
36
Sep 19, 2004 04:12 PM
hodaka100
18
Aug 10, 2004 10:10 AM
