swap question
Old Oct 22, 2005 | 01:28 PM
ggangtong81's Avatar
Default swap question
do i need to change any parts if i am putting z6 long block from 90 to my 95 ex? i know it's 90 is obd0 and my ex is obd1. any help is appreciated. thanks.
Old Oct 22, 2005 | 01:43 PM
psegs80's Avatar
Default Re: swap question (ggangtong81)
To use ur current harness you will need a jumper to go from 0bd1 to 0bd0...normally aboout 60$-75$ on Ebay Has for sensors I don't know for sure but by converting back to obd0 ( witch is your engine) you shouldn't have any sensor problems!!!
Old Oct 22, 2005 | 01:56 PM
nub's Avatar
nub
the z6 was available 92-95 (obd1) your 95 ex has a z6 in it unless someone swapped it direct bolt in
Old Oct 22, 2005 | 03:21 PM
Default Re: swap question (nub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub &raquo;</TD></TR><TR><TD CLASS="quote">the z6 was available 92-95 (obd1) your 95 ex has a z6 in it unless someone swapped it direct bolt in</TD></TR></TABLE>
yes i know my ex has z6 obd1. but my question was whether i need to change anything else if i want to put z6 from 90 which is obd0.
pjr710
Aug 12, 2008 03:28 PM
#1nismo
Feb 10, 2005 09:12 AM
hatchback_al
Sep 27, 2004 11:31 AM
^Sammy]!.
May 9, 2004 04:09 PM
