steering
Old Oct 22, 2005 | 12:47 PM
EJ8 GSR-T's Avatar
Default steering
So i have a civic ej8 coupe its lowered on tiens and stock struts, with all around camber kits, but at higher speeds i kinda get nervous cuz the steering wheel moves around a bit and it just dosnt feel to solid or tight..if that makes any sence...what can i do about this?
Old Oct 22, 2005 | 01:00 PM
. O M E G A's Avatar
3rd g3aR vTak
Default Re: steering (userdead626)
Bushings ?
Old Oct 22, 2005 | 01:24 PM
fishbiker15's Avatar
Default Re: steering (omega02379)
I would check the bushings like omega02379 said thats what was wrong with mine good luck
Old Oct 22, 2005 | 01:30 PM
m00nr0ck Si's Avatar
Default Re: steering (fishbiker15)
I have the same car , same springs, stock struts, spc camber kit f+r, all new bushings (energy suspension) , rear trailing arm bushings, new tie rods, with a good steering rack(manual), and mine does the same thing! the most recomended advice from people on here and from shops is to get new struts, koni yellows,kyb agx, tokico illumina adj.
Old Oct 22, 2005 | 07:02 PM
EJ8 GSR-T's Avatar
Default Re: steering (dorkoftheyear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorkoftheyear &raquo;</TD></TR><TR><TD CLASS="quote">I have the same car , same springs, stock struts, spc camber kit f+r, all new bushings (energy suspension) , rear trailing arm bushings, new tie rods, with a good steering rack(manual), and mine does the same thing! the most recomended advice from people on here and from shops is to get new struts, koni yellows,kyb agx, tokico illumina adj. </TD></TR></TABLE>
allright well thanks for the info, ive been lookin into the illuminas so ill tell ya how they are!
Old Oct 22, 2005 | 08:16 PM
my bro. has illuminas on his 2000 Si and they ride pretty good considering he is running H&R sports (pretty low).
ScottF
Jan 16, 2010 03:56 PM
blackhbkid
Mar 8, 2009 03:20 PM
BRN12345
30
May 12, 2008 10:56 PM
leeharveyoswald
May 22, 2007 07:40 PM
vteg
May 22, 2002 06:17 PM
