new to the efs help answer some ? for me
the first ? i have is the motor i have in it just says zc on the block what are the specs on this motor the guy i got it from said it a obd1 motor so i need to wire it up with the obd1 intake dizzy and ecu
the 2nd ? i have is i i have an eg with a pretty new front end on it new struts and rotra big brake kit will this stuff work on my ef i really hope so if not ill have some stuff for sale
thanks for all the help
i thought ZC were obd-0. i would sell it and buy a b-series. more reliable.
as for front end parts, the SHOCKS will work as long as you carry over the shock forks that go with the shocks. the ef opening is smaller than the eg. the brakes may fit on the ex knuckles. but im not sure if they will fit on the others. what size brakes were on your eg before the upgrade?
thats what i thought about the zc but it has a vtec head so maybe it as just a mine me swap i dont know but i waas told to use my intake and duzzy and ecu to get the vtec to work
and the brakes were stock before i did m brake upgrade i think there 11in rotors now i wound hat to not use them because they have less than 3000miles in them
SUP MAN, I HAVE GOTTEN AN EF AND I HAVE A B16A1 IN IT AND IT GETS DOWN. IF I WERE I WOULD DEAFENTLY GET A B SERIES ENGINE. IT IS MORE RELIABLE AND YOU WILL HAVE A BIGGER VERIETY OF PARTS. I AM ABOUT TO RUN 10 LBS. OF BOOST ON IT AND IT WILL BE NASTY OFF THE LINE
i havent drivin the car that much but the zc seems like a strong motor and its a sohc zc
but does any one kno if i can swap over my brakes i want to get a def answer
