axle nut
Old Oct 22, 2005 | 09:04 AM
Honda Crx's Avatar
Default axle nut
well in my previouse post you would see that i broke both axles and now the axle nut seized up i usually cut them in half but thats when i had my dads tool is there any other way i get this thing off
do you have suggestions with getting it off i used a impact snap on gun with a 60 gallon ac... no heat i have no torch. i used pb blaster wd40
Old Oct 22, 2005 | 09:24 AM
Honda Crx's Avatar
Default Re: axle nut (Honda Crx)
anybody
Old Oct 22, 2005 | 10:20 AM
vsm_EJ6's Avatar
Breaker bar with a 6' pipe and some friends with they are around.
Old Oct 22, 2005 | 10:45 AM
Honda Crx's Avatar
Default Re: axle nut (vsm_EJ6)
i will do
Old Oct 30, 2005 | 08:50 PM
hondahatch741's Avatar
breaker bar makes takeing it off cake trsut me it took me 3 days till i bought the bar .. its the best tool in my garage right now!
Old Oct 31, 2005 | 06:16 AM
kinkyintegra's Avatar
Default Re: axle nut (hondahatch741)
im in the same situation as this person except i have used breaker bars and have broken about 4 half inch breaker bars hooked up to 6 foot pipes....and yes ive sprayed down the nut and undid the dimple....my cars been sitting there for almost a month now all broken....im afraid to go buy a 3/4 inch breaker bar because i feel like itll break...what do people suggest, remember theres no way of me getting to an impact wrench and torch
Old Oct 31, 2005 | 07:52 AM
Crazydave's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Crx &raquo;</TD></TR><TR><TD CLASS="quote">
do you have suggestions with getting it off i used a impact snap on gun with a 60 gallon ac... no heat i have no torch. i used pb blaster wd40 </TD></TR></TABLE>
You need more pressure in the tank.
I usually crank it up to 140+ PSI
You also will need a real impact socket not a chrome one.
Old Oct 31, 2005 | 08:17 AM
vsm_EJ6's Avatar
Default Re: axle nut (kinkyintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinkyintegra &raquo;</TD></TR><TR><TD CLASS="quote">im afraid to go buy a 3/4 inch breaker bar because i feel like itll break...what do people suggest, remember theres no way of me getting to an impact wrench and torch</TD></TR></TABLE>
Go to Walmart or any hardware store and pic up one of(or similar to) these bitches.
Old Oct 31, 2005 | 08:43 AM
vtecn8ive's Avatar
I've ran into this problem at the junkyard. 2 breaker bars, an extension (which should never have been there), a ratchet (which i learned my lesson never to use that again)
And one bent breaker bar.
What kind of breaker bars are you guys using that will hold up to this?
Oh and I used PB buster.
To help you out I just ended up taking the axle with me and took a impact wrench to it.
I've yet to come across a bolt my impact won't pull of
Old Oct 31, 2005 | 09:11 AM
vsm_EJ6's Avatar
Default Re: axle nut (vtecn8ive)
1/2" craftsman breaker
Old Oct 31, 2005 | 09:52 AM
skunked's Avatar
you can also use a "nut splitter". We bought one at Sears for my buddies EF axle nut after it broke two 6' breaker bars.
Old Oct 31, 2005 | 11:10 AM
96b18c's Avatar
Default Re: axle nut (skunked)
try using the handle for your jack if it's beefy enough, and then connect it to a 1/2 ratchet/breaker bar whatever you have. some people don't use ratchets but that's how I always do it lifetime warranty on ratchet.
spens 91 Ef
10
Jan 27, 2009 07:47 PM
lude98SH
Aug 2, 2007 07:27 AM
ricerodder91EX
33
Apr 14, 2007 12:24 PM
Honda Crx
33
Oct 26, 2005 07:55 AM
2k1_ITR_0736
14
Jan 13, 2003 10:48 PM
