Front Left Pulser - ABS Code 22: Any Info or Remedy?
Old Oct 22, 2005 | 04:14 AM
EnjoyTheRideDC2's Avatar
Default Front Left Pulser - ABS Code 22: Any Info or Remedy?
Noticed my ABS light would illuminate on and off every so often. This randomly occurrs when I come to a complete stop or stop and go traffic. Its not consistent with a style of driving, because I've driven both normal and hard with no pattern to when it comes on.
Can anyone tell me what an ABS Pulser is? Or maybe a way to fix this issue? All help and info is appreciated.
Old Oct 22, 2005 | 07:50 AM
Default Re: Front Left Pulser - ABS Code 22: Any Info or Remedy? (EnjoyTheRideDC2)
Searching for an answer..........
Old Oct 22, 2005 | 09:42 AM
TTT
Old Oct 22, 2005 | 09:54 AM
tremor86's Avatar
The Pulser is the ring on the axle that the wheel speed sensor gets its reading from. Take a look at the ring and see if there are any marks, chips, or inconsistencies with the pattern which might make it get a bad reading. I work for Acura and per our troubleshooting, it says that if there is no chips in the teeth whatsoever, check for a loose connection at the abs control unit. If everything checks out ok there, you have a bad unit.
Old Oct 22, 2005 | 10:47 AM
Default Re: Front Left Pulser - ABS Code 22: Any Info or Remedy? (tremor86)
tremor86: You are the fuc**n man yo! I'll check up on this right away. THanks for the info!
Doc_Stu
Apr 11, 2008 05:18 PM
urosch
Jul 18, 2007 01:35 PM
MK Ultra
Jul 1, 2002 11:21 PM
Dirt
Jun 6, 2002 05:16 AM
