B16 Block with B18C Head???
Old Oct 22, 2005 | 02:53 AM
JspecCivic94's Avatar
Default B16 Block with B18C Head???
I have a B16 Block with a GSR B18 Head, is this a good swap? Would a LS Block be better then a B16 Block?
Old Oct 22, 2005 | 07:01 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: B16 Block with B18C Head??? (JspecCivic94)
It's okay, it's basically a stock engine you have there. A B16 head would be better suited for the B16 block, but a GSR head is okay too.
An LS block would make it an LS/Vtec, and would require more work/modifications to make it work. It depends on what your goals are.
Old Oct 22, 2005 | 07:15 AM
1SlowB16EF's Avatar
a gsr head on a b16 will if i am not mistaken make less compression due to the b18 head haveing larger combustion chambers
Old Oct 22, 2005 | 10:50 AM
HomeDepotMade's Avatar
Default Re: (1SlowB16EF)
well unless u like to boost then the lower c/r would be nice. or sell the b16 bottom and get a GSR bottom. more trq. somewhat and higher c/r.
Old Oct 22, 2005 | 12:47 PM
PURPLETERROR aka BIGMATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowB16EF &raquo;</TD></TR><TR><TD CLASS="quote">a gsr head on a b16 will if i am not mistaken make less compression due to the b18 head haveing larger combustion chambers</TD></TR></TABLE>
you are mistaken, a p72 gsr head has a smaller combustion chamber, and will give you roughly a .5 increase in compression
Old Oct 22, 2005 | 03:54 PM
mmuller's Avatar
Mad Scientist
Default Re: (PURPLETERROR aka BIGMATT)
on my book the real advantage of using a p72 head on a b16 is the ability to use iab's
can help b16 mid range
Old Oct 22, 2005 | 06:39 PM
-=Zeqs=-'s Avatar
Default Re: (mmuller)
I would rather use a B18C head on a B16A block for the compression. Given a choice between the B16A block or B18B block though, I'd rather use the B18B block for the extra displacement.
Old Oct 24, 2005 | 11:04 PM
Default Re: B16 Block with GSR Head
well the head has Crower Valve Springs and Retainers and has ITR Cams and Valves...I just got a Skunk2 Pro Series Manifold....So is the B16 Block good for all motor or anyone considering a different block? I have a older style LS block here I can build but im not really sure what all I would need to convert it to LS/Vtec
Old Oct 25, 2005 | 06:26 AM
Hecdosage's Avatar
Default Re: B16 Block with B18C Head??? (shamoo)
A b18c head on a b16 is better it bumps up your compression thus gives you more power so it is better. Then a stock b16 Put some CTR pistons or some higher compression pistons and your better. That set up is better reving then a lS vtec but the LSVtec will give you more torque about 20lbs more
pcguy760
Apr 26, 2005 09:40 AM
EFin' Kyle
Aug 8, 2004 02:35 AM
Littletrim7
Sep 23, 2003 09:06 AM
CBR
Aug 19, 2002 07:18 AM
