1988 2.0Si passenger side vibration.
just picked-up this 88' prelude and noticed some vibration on the front passenger side while on the freeway and it gets really worst when I immediate accelerate past 65mph. I changed the clutch & axle shaft. The struts are still solid and the tires are correctly balanced. So, what do you think??
Thanks
Thanks
its your wheel bearing,to check it lift the car up
on the side that vibrates and check to the wheel for any play if there is play replace the bearing, if not it can be the alignment the toe
might be off
might be off
Reyracer19
May 19, 2010 09:30 AM
Pagley
Oct 15, 2009 09:01 AM
longshot
Oct 8, 2008 10:59 PM
