EK pulls right under throttle but not coasting
Alignment was done at 2 separate places and the car still pull to the right under any throttle, but while coasting or breaking the car is straight and great.
Could it be a LCA issue? or maybe an axle issue?
car is stock, just dropped but I know that's wearing out my new tires
I'm stuck so any help would be appreciated.
Rey
Rey
Re: EK pulls right under throttle but not coasting
1. Check wheel bearing.
2. Check all bolts that connect the front lower control arm to the subframe.
About the wheel bearing, how will i know it's gone bad? will it be loose or make any sound while driving?
my car did that once, got it aligned wit S2 kit all around and still pulled, ended being an axle. wheel bearing will make noise depending how bad it is, and feel loose when wheel is up in the air and you grab the wheel and will have play, also make sure your tie rods are good. some alignment shops just do alignments and dont check balljoints and/or tie rods
DeDonDeRosa
09-09-2006 06:43 PM
