grounding wires installation
Old Oct 21, 2005 | 08:13 PM
mars's Avatar
Default grounding wires installation
ok, this might sound a little stupid, but I just got a grounding wire for my 5 gen , One questions here.i know one end connect to my battery's negative side and where the other ends connected to (total five wires)? thanks for all helps.
Old Oct 22, 2005 | 12:50 AM
momstaxi's Avatar
Default Re: grounding wires installation (mars)
its not really that hard man, here you go assuming you have the hyperground system knockoff set....
youll have to use a little brain power and reverse the image though, as honda engines are layed out in a mirror format.....
Old Oct 22, 2005 | 10:56 AM
mars's Avatar
thx for the help.
i look it up and locate the place,
but another thing i have is i couldn't find a screw which i can connect my wire on
it's seems the screw is too big for my wire's head?
forgive me if i keep saying stupid
Old Oct 22, 2005 | 11:04 AM
momstaxi's Avatar
Default Re: (mars)
well i had this onmy car before and i found spots for them all to mount...
for the trans ground use the point where the negative battery terminal grounds, a bracket towards the bottom of the trans. for the cylinder head ground, i used the empty bolt hole next to the distributer, on the front of the head. (i had to use my own bolt, i believe its m8x1.00) for the intake manifold ground i removed one of teh 12mm nuts that hold on the upper piece of the intake manifold, then for both chassis grounds there are 10mm bolts on both sides you can use...
Old Oct 23, 2005 | 09:34 AM
mars's Avatar
thx, momstaxi. i think i got it !!
Old Oct 23, 2005 | 02:24 PM
Obsidian's Avatar
Default Re: (mars)
Next question then, did this kit make a damn bit of difference?
stevenr2894
10
Mar 9, 2013 10:23 AM
ilikemyaccord
Oct 19, 2006 07:16 AM
jordan-boxer
Audio / Security / Video
12
Nov 21, 2005 09:18 AM
fernanie2002
Nov 6, 2002 01:30 PM
Trigun
Apr 16, 2002 08:48 AM
