Welding between the thinnest sections in collectors
The thinnest section between the pipes in this collector, similar to the one i plan on fabricating, how do you all weld the runners onto the collector between there?
It looks like an impossibly small space to get even a small tig torch in....
yuo cant weld it in the inside of a 5inch long collector unless someone made a tig torch that can weld with the tungstun extended like 4 inches out and can still get gas coverage inside
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wade »</TD></TR><TR><TD CLASS="quote">yuo cant weld it in the inside of a 5inch long collector unless someone made a tig torch that can weld with the tungstun extended like 4 inches out and can still get gas coverage inside</TD></TR></TABLE>
what if you trapped the gas inside the area to be welded?
this is something that takes a serious amount of practice, but can be done. i promise.
i'll post some pictures of jesse and andys PeakBoost collector welds a little later.
edit: patience and welding go hand in hand
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotommy »</TD></TR><TR><TD CLASS="quote">pen torch..
Yup.
</TD></TR></TABLE>Yup.
is this ken? from phoenix.? the blowzilla is on a diff car now, Its in a 2.4L h22 civic, my setup gave out on me. blowzilla took it out! i now sold that car, have a EBP 99 Civic Si boosted now stock block, so it isnt much fun. im trying to save up and get a built block for the summer! PS i need some of those red phoenixturbo shirts. In large...
My local welding shop has welding cups for my miller torch that are about 4 inches long, with a pretty narrow tip. they are invaluable for getting into tight spots. Sometimes, you can weld the inside of the collector in the middle of the merge where the other side is inaccessable.
Im looking for a good way to cut the pipes on collectors. My Plasma works alright, but it takes more cleaning up of the cut than i'd like, and my reasonably strong bandsaw just sucks with stainless 18 gauge. Anyone have a good method?
purge cabinet
purge cabinet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP »</TD></TR><TR><TD CLASS="quote">purge cabinet</TD></TR></TABLE>
sounds expensive, and hard to fit in my garage at home with everything else in there.. lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jays91DXhatch »</TD></TR><TR><TD CLASS="quote">
sounds expensive, and hard to fit in my garage at home with everything else in there.. lol</TD></TR></TABLE>
You can use an old small sand blasting cabinet. Just use something size appropriate to keep the purge gas costs down.
R6E6I6D
Welding / Fabrication
10
Nov 1, 2005 09:11 PM
