turboing 11:1 comp built 84mm c5....questions.
im toying with the notion of turboing my current all motor setup. its a ge sleeved wiseco piston eagle rod setup. is it safe to boost since its built or should i get that compression down lower? i kinda wanna do a lower boost and high comp im sure it will make some nice numbers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedDreamz.com »</TD></TR><TR><TD CLASS="quote">Yep, go with an .043 headgasket to help out.</TD></TR></TABLE>
Thinner than stock?? No?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 »</TD></TR><TR><TD CLASS="quote">be easy on timing and generous on fuel and you'll be fine as long as u dont go crazy on boost with pump gas.</TD></TR></TABLE>
Took the words right out of my mouth^^. I had an 11.5:1 setup and even though it was a bitch to tune, it was fun in the end. Did 11.70's @ 120+mph on 12psi out of a t04e. Motor was killed by oil starvation though
Phil
Phil
you guys should check out this guys dyno his member name is (plusONErandy). stock internal type r motor. slappedon turbo,made decent power on 91 octane. highcompression turbo. **** is crazy .i got he video,ill post if u want me to.it made 266hp 195 stock internals.He dyno it yesterday.
one slow coupe
Mar 19, 2006 05:52 PM
Wo-Nelly
Feb 1, 2004 05:53 AM
