Rattling noise from engine bay..throw out bearing????
Old Oct 21, 2005 | 07:40 PM
1QuikSOHCZC's Avatar
Default Rattling noise from engine bay..throw out bearing????
when i push the clutch down it goes away and when i realse it its rattles ..i hate it it bugs me...im pretty sure its the bearing....so i might jus get a new clutch kit anyway its about time i did....can anyone verify that maybe the throw out bearing is making the noise?
Old Oct 24, 2005 | 01:18 AM
Default Re: Rattling noise from engine bay..throw out bearing???? (1QuikSOHC)
Bump sumones got to know
Old Oct 25, 2005 | 05:11 PM
jdeemseerx's Avatar
what kind of car? do you have hydraulic or cable clutch, its def the t.o. bearing but the reason i say this is bc ive seen shift forks on hydraulics get worn, the bearing not seating right and causing vibration..meaning you need a new shift fork not the bearing, but if its cable your most likely need a bearing ive also seen the sleeves on the side of the bearing bend and break,, when i change a clutch i always change the shift fork as well on both cable and hydraulic
redman223
Mar 1, 2024 01:55 PM
Aron Parsons
Mar 6, 2006 09:18 PM
pa2play
Jul 28, 2005 09:42 AM
tylerdurden
Mar 26, 2003 06:41 PM
