!!##big problem with instrument panel and tail lights! No Illumination!##!!
Old Oct 21, 2005 | 06:45 PM
skimeast1982's Avatar
Default !!##big problem with instrument panel and tail lights! No Illumination!##!!
Scenario: Had a friend of my install a new alpine deck in my 99 Prelude. We did it this afternoon and everything checked out. I go to get in it after work at night. Deck works perfectely! Car starts fine. Everything is fine except for two things.
1. Instrument panel lights do not work! Speedo/tach lights do not light up when headlights are turned on or off. Vent controls, heating buttons, etc. Do not light up. Intresting enough the high beam icon lights up when high beams are on. Signal light icons go on when signal lights are used. Icon telling what gear I'm switching through and into are fine. Everything else....no illumination.
2. Tail lights do not go on. When lights are on or off. No illumination. When pressing the break they light up...but then released. Nothing.
Checked and rechecked the wiring.
Checked and rechecked the fuses.
Everything checks out.
What is wrong!?
Any ideas!?!?!?!?
Old Oct 24, 2005 | 04:34 AM
ThE PiMpiN Co's Avatar
Default Re: !!##big problem with instrument panel and tail lights! No Illumination!##!! (skimeast1982)
check your ground wires
Old Oct 24, 2005 | 07:55 AM
kulrevon's Avatar
Default Re: !!##big problem with instrument panel and tail lights! No Illumination!##!! (aRaBiAn RiCe)
check your ilumination wire on your headunit. maybe the kid didnt tape it up.
I had a problem that the ilumination wire (maybe orange) hit a ground and popped my fuses. it was after someone stole my radio so the wireing was kinda messed up.
I think your fuse is blown weather you no it or not.
Old Oct 24, 2005 | 11:28 AM
prelude1897's Avatar
Default Re: !!##big problem with instrument panel and tail lights! No Illumination!##!! (kulrevon)
Recheck every fuse inside and under the hood...If they all look good, then maybe you multiplex unit has fried....
Luke G.
Jan 2, 2009 03:49 PM
JDMoneDC5
Dec 8, 2008 12:18 PM
95integrags-r
Mar 30, 2006 05:41 PM
skimeast1982
Audio / Security / Video
Oct 22, 2005 11:33 AM
