rattling after header install
Old Oct 21, 2005 | 05:04 PM
LudeJdm's Avatar
Default rattling after header install
hey just wondering if anyone has had this before...i installed my dc header a couple months ago and since then ive been hearing rattling noises @ 1500rpm or any low idle....it rattles at stop lights....just wondering if anyone has had this problem...its the most annoying sound ive ever heard...i know its not the heat shield cuz i dont have one....can anyone help me figure out how to fix this problem
Old Oct 21, 2005 | 05:08 PM
SiR Inspired ED7's Avatar
Default Re: rattling after header install (HdA1T6CzH6)
try tightening the bolts they might have got loose since u probably didn't line up the header to piping correctly.
Old Oct 22, 2005 | 11:01 AM
LudeJdm's Avatar
Default Re: rattling after header install (88 Crx Si)
nope not it....BUMp
Old Oct 22, 2005 | 11:44 AM
EL Vap133's Avatar
There is a metal bracket that the header hangs onto, did you use it?
Old Oct 22, 2005 | 11:45 AM
LudeJdm's Avatar
Default Re: rattling after header install (EL Vap133)
nope
Old Oct 22, 2005 | 12:18 PM
theinfamouskonrad's Avatar
might be coming close to that front crossmember depending on what engine you have in there.
Old Oct 22, 2005 | 12:25 PM
STREETWERKZ's Avatar
dont hand tighten your o2 sensor.....
i made that mistake, i THOUGHT it was tight, but rattled loose, was annoying as expletive untill i realized what it was.
Old Oct 22, 2005 | 12:41 PM
Its me DUB's Avatar
Default Re: rattling after header install (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">dont hand tighten your o2 sensor.....
i made that mistake, i THOUGHT it was tight, but rattled loose, was annoying as expletive untill i realized what it was. </TD></TR></TABLE> Same thing happened to me. The o2 sensor may be the culprit...
Old Oct 30, 2005 | 01:40 PM
LudeJdm's Avatar
Default Re: rattling after header install (doitdub)
can it be the donut gasket???? can dc headers be too long????
Old Oct 30, 2005 | 01:55 PM
LudeJdm's Avatar
should the header have come with the gasket??? cuz mine didnt....
Old Oct 30, 2005 | 03:59 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">There is a metal bracket that the header hangs onto, did you use it? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HdA1T6CzH6 &raquo;</TD></TR><TR><TD CLASS="quote">nope
I bet that's where it's rattling at.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HdA1T6CzH6 &raquo;</TD></TR><TR><TD CLASS="quote">should the header have come with the gasket??? cuz mine didnt....</TD></TR></TABLE>
That's why you use your old one.
Old Oct 30, 2005 | 05:21 PM
LudeJdm's Avatar
ill go check dat out tomorrow
Old Nov 1, 2005 | 08:38 PM
LudeJdm's Avatar
can it be the heat shield on the cat??
Old Nov 1, 2005 | 08:51 PM
could be.
but seriously.... did you use new donut gasket where the header meets the cat?
did you use a new exhaust manifold gasket at the head?
if it s a 2 piece header, did you use new donut gaskets in between the two?
is the O2 sensor tightened with a wrench? or did you screw it on by hand?
Old Nov 1, 2005 | 10:31 PM
Stunna MIKE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">could be.
is the O2 sensor tightened with a wrench? or did you screw it on by hand? </TD></TR></TABLE>
Old Nov 2, 2005 | 08:01 PM
LudeJdm's Avatar
Default Re: rattling after header install (AaronJDM)
anyone know where i can buy the donut gasket and how it looks like???
Old Nov 2, 2005 | 09:08 PM
uhhhh, honda.
and it looks like a donut.
Old Nov 2, 2005 | 10:20 PM
SD_Lurker's Avatar
HT White Ops
maybe your cat is shot and its rattleing all the debris in it???
Old Nov 3, 2005 | 07:58 AM
LudeJdm's Avatar
Default Re: rattling after header install (nicks_jdmstyle_ef9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicks_jdmstyle_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">maybe your cat is shot and its rattleing all the debris in it???</TD></TR></TABLE>
nope that isnt it cuz i know how that sounds like and it aint it...
Old Nov 8, 2005 | 09:17 AM
RudeBwaiSi's Avatar
More than likely thats the problem. If you get a flex pipe, it might stop the rattling.
marshman
Honda S2000
34
Feb 21, 2007 04:02 PM
Amused
Aug 23, 2006 05:34 AM
jeffk182
19
Jan 26, 2005 09:22 AM
jweezy225
Aug 15, 2004 01:32 PM
1slow_si
Apr 24, 2004 05:58 PM
