oxy-acetalyne noob here; can't get keyhole to stay in square butt weld
Old Oct 21, 2005 | 03:57 PM
ladius's Avatar
Default oxy-acetalyne noob here; can't get keyhole to stay in square butt weld
Hey all,
I'm taking an intro welding class at my local community college where we're starting off learning oxy-acetalyne welding. i'm trying to master a square butt weld with good penetration but either can't get the keyhole to form or it becomes a huge hole.
i've seen the instructor do it twice and i am copying him directly but i still can't get it right. could someone give a little insight into this?
fyi, the thing sparks up like crazy and pops a lot with tons of burning smell. yes, i want to point the blame at something else, could it possibly be that the materials are tainted?
TIA
Old Oct 21, 2005 | 08:21 PM
KFMRC's Avatar
Default Re: oxy-acetalyne noob here; can't get keyhole to stay in square butt weld (ladius)
try to you a llittle more acet. You probably have a really pointed flame and I have always found that to be a real problem. Use a flame that has a very slight fuzziness to it and it will get rid of most of the popping. You also need to use the right size tip. If the teacher can use the tip with no problems then the tip size should be fine.
Old Oct 22, 2005 | 04:15 PM
ladius's Avatar
Default Re: oxy-acetalyne noob here; can't get keyhole to stay in square butt weld (KFMRC)
yeah, my cone is very pointed. i'll try lowering the flow of acetylene and give that a shot.
Thanks!
Old Oct 22, 2005 | 06:14 PM
RCautoworks's Avatar
Make sure the tip is clean.
Old Oct 22, 2005 | 08:08 PM
KFMRC's Avatar
you actually need to increase the flow of acet. to soften the point
Old Oct 23, 2005 | 01:11 AM
19civic93's Avatar
you have to increase acetylene because too much oxygen will burn holes. example is when you use a cutting torch. it's the high flow of oxygen the cuts the steel.
Welding / Fabrication
Feb 8, 2010 08:21 PM
jdm.fanatic
Feb 4, 2009 10:31 AM
kb58
19
Mar 29, 2008 09:37 AM
LawlessOne
Jun 18, 2006 01:41 PM
ciRcuitJerk
Mar 14, 2003 12:53 PM
