o2 problem, how do i do this?
Old Oct 21, 2005 | 02:05 PM
dogbiscuit's Avatar
Default o2 problem, how do i do this?
i am trying to change my o2 sensor and i can not get the old one out, i have damn near broken my back trying to get this fukin thing off. is there a trick to doing this? i am only 125lbs and don't have much power behind my ***. also should i start the engine for a minute and let the exhaust heat up and then try and remove the o2 sensor. it won't budge with the exhaust being cold.
how do i do this?
Old Oct 21, 2005 | 02:58 PM
littleredcivic's Avatar
Default Re: o2 problem, how do i do this? (dogbiscuit)
what kind of engine and car is it in? you can try using some liquid wrench on it, spray it all over and get it between the o2 and the bung...it will soak for a little while, then try it again. if not, take the damn pipe out and put it on a vice. use a big *** breaker bar and get that thing out. if that is not an option, get a torch and try to get it real hot...don't catch anything on fire.
Old Oct 21, 2005 | 03:32 PM
Brodie Bruce's Avatar
Get one of those sockets made specifically for O2 sensors. I got one because I am always taking mine in/out and it made changing them so easy. Any auto parts store for about $8.
Old Oct 21, 2005 | 04:46 PM
92civichatch1's Avatar
Default Re: o2 problem, how do i do this? (xavenged7x)
Spray the **** outta it with like a WD-40. let it soak for an hour or so. then rip it off.
otherwise go with this...<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by littleredcivic &raquo;</TD></TR><TR><TD CLASS="quote">what kind of engine and car is it in? you can try using some liquid wrench on it, spray it all over and get it between the o2 and the bung...it will soak for a little while, then try it again. if not, take the damn pipe out and put it on a vice. use a big *** breaker bar and get that thing out. if that is not an option, get a torch and try to get it real hot...don't catch anything on fire.</TD></TR></TABLE>
Old Oct 21, 2005 | 05:12 PM
tmramsburg's Avatar
PB Blaster (penetrating lube)
Old Oct 25, 2005 | 02:48 PM
dogbiscuit's Avatar
Fixed autozone rented the socket set for $16, the thing came right out with a 4 ft pipe on the end of my wratchet
rudebwoy
Dec 24, 2009 11:36 AM
EJ8_Enthusiast
Sep 17, 2008 04:48 PM
Secret Chimp
Oct 15, 2007 12:14 PM
SpoonEk253
Mar 22, 2006 06:10 PM
Sir_Phobos
Feb 15, 2003 10:55 AM
