engine makes this clunking noise when I'm in a low RPM 2nd or 3rd gear
Old Oct 21, 2005 | 01:43 PM
piggydog's Avatar
Default engine makes this clunking noise when I'm in a low RPM 2nd or 3rd gear
it's always when turning (I'm going slow) then accelerating in 2nd at low RPM's. It makes this fairly loud clunking noise. It only happens at low RPM's. I'm not in first because it rides too jerky going to first on a turn.
Old Oct 21, 2005 | 02:07 PM
Sabbotage's Avatar
Default Re: engine makes this clunking noise when I'm in a low RPM 2nd or 3rd gear (piggydog)
sounds like your cv joints are bad.
Old Oct 21, 2005 | 02:35 PM
piggydog's Avatar
Default Re: engine makes this clunking noise when I'm in a low RPM 2nd or 3rd gear (Sabbotage)
I thought this also but this only happens at low RPM's?
Old Oct 21, 2005 | 06:41 PM
onefastrx7turbo's Avatar
its not rpms dependant. its turning dependant. when you turn at any speed/any rpms, they click and clunk....sounds like its time for new ones....
neil
Old Oct 21, 2005 | 07:14 PM
piggydog's Avatar
Default Re: engine makes this clunking noise when I'm in a low RPM 2nd or 3rd gear (onefastrx7turbo)
yes but if I'm coasting and turning it makes no noise. Only accelerating under load (going uphill seems to the noise is lounder)
Old Oct 22, 2005 | 09:53 AM
LudeyKrus's Avatar
Try checking your motor mounts for me; it may be the motor rocking and knocking in what's left of its mounts.
Old Oct 22, 2005 | 10:43 AM
piggydog's Avatar
Default Re: (LudeyKrus)
thx for the suggestions. I will check those things out. Hopefully it won't be too expensive
Steam Driver
Mar 27, 2014 03:29 AM
h0ndaSi
Honda Civic (2006 - 2015)
13
Oct 30, 2012 04:56 PM
Rainson24
Sep 7, 2008 05:00 AM
PennStateZ
Mar 15, 2008 09:01 AM
caliprelude3087
Aug 26, 2004 10:02 PM
