compression test
Old Oct 21, 2005 | 01:37 PM
sheBangZ's Avatar
Default compression test
ok, i searched this topic over and over again and still everyone still has different opinions on how to do it. pull this, pull that, disconect this, no don't do that you'll hurt this. . does anyone on here really knows how to do a compresion test correctly, won't fry anything and get the proper numbers. no offense to anyone but there is 840 topics on it and no one seems to agree with each other. there cannot be 50 ways to do a simple compresion test. what do i pull, ecu fuse, what line to the distributor do i pull, what fuse. I am just lost bad.
Old Oct 21, 2005 | 02:28 PM
civic_dork's Avatar
Default Re: compression test (sheBangZ)
Common sense, the directions that came with the compression tester, and the shop manual....
Old Oct 21, 2005 | 02:34 PM
aka's Avatar
aka
http://www.c-speedracing.com/h...t.php
Old Oct 21, 2005 | 03:03 PM
Its me DUB's Avatar
Default Re: compression test (civic_dork)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_dork &raquo;</TD></TR><TR><TD CLASS="quote">Common sense, the directions that came with the compression tester, and the shop manual....
If it's common sense, why don't you help him out like aka?
Old Oct 21, 2005 | 03:21 PM
civic_dork's Avatar
Default Re: compression test (doitdub)
If it's not common sense then why have so many people successfully accomplished the task?
If you have a better answer than mine, GIVE IT, don't just call somebody out because you have nothing good to add.
Furthermore, if you search you'll find that article is part of the controversy.
... such as don't just go cranking it 5 times and see what the reading is... watch the gauge AS you crank it to see if the compression jumps right up, or if the compression slowly builds with each stroke (basic test for testing bad rings vs. bad valves). (all of which is explained both in directions and the manual)
Furthermore if it were merely common sense i would not have added that the manual and directions are required... because all the necessary info is in those 2 sources.
Old Oct 21, 2005 | 03:37 PM
aka's Avatar
aka
maybe he doesn't have the original package or service manual. idunno. No need to bicker. Your in tech support.If there is a question to be answered... answer it.
Old Oct 21, 2005 | 03:46 PM
EHondaD6's Avatar
Disconnect:
-power to distributor=two pin plug @ distributor
-power to injectors=disconnect each injector individually(or injector resistor box)....
-remove all spark plugs
-crank engine with throttle wide open until needle stops moving up, thats your psi in each cyl.
you may have some dtc's after the test is done, but you could just clear them buy disconnect the battery...
GSR_hatch936
Apr 5, 2007 11:04 AM
Mr.Death
15
Aug 18, 2006 02:10 PM
watsvtecEK
Dec 12, 2005 07:28 AM
Got_soy
28
Aug 8, 2005 12:49 PM
snowblind7x
Apr 13, 2005 08:12 PM
