can't unscrew crankshaft bolt
Old Oct 21, 2005 | 11:10 AM
kpringcivic's Avatar
Default can't unscrew crankshaft bolt
I'm changing the timing belt (and hopefully that will be all!) because it broke. I have broken a 1/2 socket trying to unscrew the bolt going counterclockwise and I have an impact socket and have tried going clockwise and I snapped a 1/2 extension I was using. What am I doing wrong. (The flywheel is wedged with a screwdriver in the bellhousing. I just sprayed some WD-40 on it in lieu of penetrating oil.) In case you are wondering, I still seem to have compression in each cylinder, so I guess I'm pretty lucky??? What is the secret to getting the bolt off??
Old Oct 21, 2005 | 11:33 AM
technine's Avatar
Default Re: can't unscrew crankshaft bolt (kpringcivic)
Try using a long pipe about 4' feet long or longer with one of your 1/2 socket wrenches. It should do the job.
Old Oct 21, 2005 | 11:47 AM
d357r0y's Avatar
Default Re: can't unscrew crankshaft bolt (technine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by technine &raquo;</TD></TR><TR><TD CLASS="quote">Try using a long pipe about 4' feet long or longer with one of your 1/2 socket wrenches. It should do the job.</TD></TR></TABLE>
.. but use a breaker bar instead of a socket wrench, I've broken a 1/2" crapsman ratchet taking off axle nuts before.
Old Oct 21, 2005 | 12:54 PM
I did use a bar about 4ft long to get the leverage needed to break those items. My biggest question is do I go clockwise or counterclockwise. I've busted the ratchets going each way, but if I new positively which way to go, I may try an impact wrench.
Kevin
Old Oct 21, 2005 | 01:29 PM
Kwicko's Avatar
It's a standard-threaded bolt. In other words, counter-clockwise to loosen (lefty-loosey, righty-tighty). That bolt always seems to be a bitch.
Old Oct 21, 2005 | 03:12 PM
SuperSteve737's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpringcivic &raquo;</TD></TR><TR><TD CLASS="quote"> have tried going clockwise and I snapped a 1/2 extension I was using. What am I doing wrong.</TD></TR></TABLE>
That's what you are doing wrong. It is counter-clockwise.
Old Oct 21, 2005 | 03:15 PM
EJ1 wilcox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpringcivic &raquo;</TD></TR><TR><TD CLASS="quote">I did use a bar about 4ft long to get the leverage needed to break those items. My biggest question is do I go clockwise or counterclockwise. I've busted the ratchets going each way, but if I new positively which way to go, I may try an impact wrench.
Kevin</TD></TR></TABLE>
That sucks. The same thing happened to me.
I broke two ratchets and a breaker bar trying to get it off. I used an impact on the highest setting and it wouldn't budge. I ended up having to use a 10" long breaker bar and had a friend help.
Turns out the guy who had replaced the timing belt last (the engine was used), had smeared locktite all over the threads. I mean, there was a TON of that **** up in there.
It was supposed to take 20 seconds to get that thing off, ended up taking me all damn day.
Old Oct 21, 2005 | 03:30 PM
Kwicko's Avatar
Default Re: can't unscrew crankshaft bolt (EJ1 wilcox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ1 wilcox &raquo;</TD></TR><TR><TD CLASS="quote">
It was supposed to take 20 seconds to get that thing off, ended up taking me all damn day. </TD></TR></TABLE>
I hear ya. LocTite is the devil. Hell, I smear that damn bolt with anti-seize before it goes back in!
Old Oct 21, 2005 | 06:49 PM
toxiclows's Avatar
I hate to be a dick but if you are not sure which direction the first bolt that you need to remove turns. . . then I question your ability to complete the timing belt job. . .
Seriously though. . . . the bolt can be rough i have done lots and lots of them and have never had trouble using my foot on a long ratchet 1/2 inch drive. . . and holding onto the car and pushing my body into it. . .
breaks them loose every time. .
Old Oct 21, 2005 | 06:56 PM
westspeed's Avatar
If you can find something to make the crankshaft from turning, a screwdriver wont work there is a tool that i used that goes right into the spark plug hole that blocks the piston from turning, the tip is made of brass so it wont harm anything.
once i used that and a braker bar it busted loose in ten seconds after a good kick.
or go to sears buy an impact gun use it and return it
Old Oct 21, 2005 | 07:02 PM
aspec101's Avatar
Someone needs to make a sticky on this there is a specific honda crank holder.
http://www.amazon.com/exec/obi...lance
use the right tools and do it right!
Old Oct 21, 2005 | 07:18 PM
westspeed's Avatar
Default Re: can't unscrew crankshaft bolt (vaperformance)
http://www.thepartsbin.com/car....html
this one works better i payed 15 dollars and is authorized by dealerships, i work at one.
sonny0330
May 29, 2008 06:53 AM
NSTY Z33
Welding / Fabrication
Mar 19, 2007 05:41 AM
civicEXtreme
Suspension & Brakes
Feb 22, 2006 02:36 PM
encognito
Oct 12, 2004 09:52 AM
Layziebtnh055
May 14, 2004 06:42 AM
