quick dimmer switch question...
have a 92 si. my cluster lights do not work and think it is my dimmer. i have a voltmeter and i am going to check it tonight.
my main question is, does the dimmer light switch just pop out, or is there another way to get it out?
Thanks in advance. BTW, i did search.
just yank it outta there. just use a small screwdriver and pop it out. I'm thinking you can push it out from the back I cant remember for sure if you can get to it from behind or not.
easiest to just pop it out like mentioned above. If you want a cheap repair if the switch is bad. use a paper clip as a jumper to eliminate the switch. My switch kept cutting in/out so I did this. I dont have any adjustments anymore but atleast it works.
if you tried your dimmer switch and it works for the rest of the car , then its probably just a bulb. if your entire dash and lighted components do not dim then its your dimmer switch. and it simply pops in and out.. just use a flat head. and i would pop the whole thing out not just the dimmer switch. its easier that way, and then just unclip the dimmer switch from the back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jameskersten1 »</TD></TR><TR><TD CLASS="quote"> use a paper clip as a jumper to eliminate the switch. My switch kept cutting in/out so I did this. I dont have any adjustments anymore but atleast it works.
I was going to bypass the switch if i see that it's bad...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE »</TD></TR><TR><TD CLASS="quote">if you tried your dimmer switch and it works for the rest of the car , then its probably just a bulb. if your entire dash and lighted components do not dim then its your dimmer switch. </TD></TR></TABLE>
The dimmer switch definitely doesn't do jack for anything else, so it must be that...
looks like ill be bypassing it tonight. thanks for the input guys
</TD></TR></TABLE>I was going to bypass the switch if i see that it's bad...
DC2*Integra
Audio / Security / Video
Apr 6, 2010 08:28 AM
trrbl1bmx
Jan 25, 2006 07:46 AM
