Engine Swap??
alright, so i have a 90 Teg LS, and apparently it has a 94 LS engine in it, but i was never able to check. can someone either give me a way to find the serial number on the engine or a pic of the differences between the two engines? any help would be appreciated.
If you check your Engine Identifying Numbe(EIN) There should be an imprinted number so to speak on there. If it says B18a1 then you got yourself the 90-93 integra LS engine. If it says B18b1, then that is the DC(94+) LS engine.
^^that and check the head right above the header. there should be four circles with some numbers...the first number is the year of the head...which is most a match to your block...
