Engine Swap??
Old Oct 21, 2005 | 10:34 AM
shiux's Avatar
Default Engine Swap??
alright, so i have a 90 Teg LS, and apparently it has a 94 LS engine in it, but i was never able to check. can someone either give me a way to find the serial number on the engine or a pic of the differences between the two engines? any help would be appreciated.
Old Oct 21, 2005 | 10:36 AM
BlackLudeSi's Avatar
Default Re: Engine Swap?? (shiux)
Just look at the engine code right in front to the left of the exhaust mani,
I think 90-93 B18a and 94+ B18b but i could be wrong I have a B18a in a 90 Ls
Old Oct 21, 2005 | 10:43 AM
BrooX's Avatar
If you check your Engine Identifying Numbe(EIN) There should be an imprinted number so to speak on there. If it says B18a1 then you got yourself the 90-93 integra LS engine. If it says B18b1, then that is the DC(94+) LS engine.
Old Oct 21, 2005 | 12:21 PM
ecks_fourttwo's Avatar
Default Re: Engine Swap?? (DA9GUY-637)
^^that and check the head right above the header. there should be four circles with some numbers...the first number is the year of the head...which is most a match to your block...
e jay one
Jan 13, 2006 01:09 AM
ftemanuele
Dec 17, 2004 04:40 AM
shinji666
Aug 21, 2004 11:02 AM
brasilstreet
Jan 21, 2004 07:43 PM
