Suspension & Brakes Theory, alignment, spring rates....
96 dx no sway bars
Old Oct 21, 2005 | 10:21 AM
Slosc2's Avatar
Default 96 dx no sway bars
howdy. I have a 96 dx hatch. It is currently sitting on K sport coilovers. It handles "ok" at best, but it leaves lots of room to be toyed with.
Being that It does not have front or rear sway bars, I figured even just a set of factory sway bars will help out my cravings quite a bit.
Im not sure if the ex has both front and rear sway bars. If it does, Ill probably just grab the factory bars, end links, and "C" mounts from a salvage yard, but front and rear control arms from an aftermarket source.
Basically what I want to know, is what cars could I grab the parts i need from, and are these all the parts i need?
From what i understand, i need:
Sway bars both front and rear
sway bar endlinks and "C" mounts
front and rear lower control arms.
comments, suggestions, tips are all welcome
Old Oct 21, 2005 | 09:27 PM
Slosc2's Avatar
Default Re: 96 dx no sway bars (Slosc2)
Old Oct 22, 2005 | 09:00 PM
Slosc2's Avatar
Old Oct 23, 2005 | 08:34 AM
vietnameeh's Avatar
99-00 si sways with endlinks and hardware
Old Oct 23, 2005 | 08:50 AM
jayswift's Avatar
just make sure you match up the front sway bar to the front lca's. ex: Si/CTR sway bar with Si/CTR Lca's, EX/HX (you can use DC2 one's also) sway bar with EX/HX front lca's. reason being is because they mount differently at the ends.
as for the rear, you can use your stock rear lca.
Old Oct 23, 2005 | 10:38 AM
Slosc2's Avatar
Default Re: 96 dx no sway bars (jayswift)
Thanks
1991ED6
Sep 29, 2012 01:53 PM
griffinjr123
Suspension & Brakes
Nov 16, 2009 02:53 PM
Em0ne
May 12, 2004 07:14 AM
PabloDiablo
Apr 1, 2004 05:30 PM
