Once again, water in the hatch...search done...
Old Oct 21, 2005 | 07:33 AM
bbqman's Avatar
Default Once again, water in the hatch...search done...
Just before I go tearing my car apart, I want to confirm that the general consensus on water infiltration, in the hatchback that pools in the spare tire well - is cause mainly by taillight gaskets that are worn.
I have searched and read all the topics but the latest wa in 2003 , so I figured there may be new info.
If this is the first step, I am gonna do it next week. After that, i have no idea where else to look.
While my car sits all day in the pouring rain...there is barely a a trickle in the spare well, but after a 20 mile ride in the pouring rain...I have 1 inch of water in the well.
Any ideas welcome, preferably from those who have solved a water infiltration issue.
I wonder how much water will be in my hatch after my Mosport lapping day tomorrow? the forecast rain all day.....
Old Oct 21, 2005 | 07:35 AM
Booker's Avatar
Banned Duplicate Account
Default Re: Once again, water in the hatch...search done... (bbqman)
take the grommet out of the spare tire well... Nothing will build up, but you might get some fumes if the windows are closed.
As for actually fixing it. I dunno.
Old Oct 21, 2005 | 07:37 AM
bbqman's Avatar
Default Re: Once again, water in the hatch...search done... (Booker)
Grommets? I only saw a big plug that seems quite rusted into place.
Old Oct 21, 2005 | 07:45 AM
ebelp's Avatar
https://honda-tech.com/zerothread?id=1110977
Old Oct 21, 2005 | 07:50 AM
bbqman's Avatar
Default Re: Once again, water in the hatch...search done... (ebelp)
All of a sudden, I don't feel so bad.......
Old Oct 21, 2005 | 08:04 AM
Aquafina's Avatar
Might work for your car too.
https://honda-tech.com/zerothread?id=885253
Old Oct 21, 2005 | 08:13 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebelp &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1110977</TD></TR></TABLE>
As was mentioned in the above thread I think that guy had excess patience. I probably woulda just sold the damned car.
I've owned 3 DC2's so far and knock on wood, none of them have had any leaking issues whatsoever. After reading the above post I actually felt frustrated for that poor guy.
Old Oct 21, 2005 | 08:47 AM
cannan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbqman &raquo;</TD></TR><TR><TD CLASS="quote">While my car sits all day in the pouring rain...there is barely a a trickle in the spare well, but after a 20 mile ride in the pouring rain...I have 1 inch of water in the well.</TD></TR></TABLE>
I was going to say strip the trunk and have someone spray water onto the car so you might be able to see where it is coming from. But if it sits there and nothing happens then I guess that idea is shot.
Old Oct 21, 2005 | 08:58 AM
HYREV2NR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbqman &raquo;</TD></TR><TR><TD CLASS="quote">Just before I go tearing my car apart, I want to confirm that the general consensus on water infiltration, in the hatchback that pools in the spare tire well - is cause mainly by taillight gaskets that are worn.
I wonder how much water will be in my hatch after my Mosport lapping day tomorrow? the forecast rain all day..... </TD></TR></TABLE>More than likely it's the taillight gaskets. I had the same thing happen to me on my first Honda & that was a 92 Accord hatchback. An 8mm socket fixed it real quick. I've seen this happen on more than a couple of Hondas over the years. I wouldn't try cleaning the gaskets, they might fall apart. Just tighten them.
Old Oct 21, 2005 | 10:16 AM
Opie's Avatar
Hope it all works out, Carl. See you @ Expo 6
Old Oct 21, 2005 | 10:20 AM
bbqman's Avatar
Default Re: (Opie)
If my car doesn't turn into a submarine, I will be at Expo VI...with a fresh engine.
Old Oct 21, 2005 | 10:21 AM
Opie's Avatar
Great!
Old Oct 21, 2005 | 03:21 PM
penpen's Avatar
Default Re: (bbqman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bbqman &raquo;</TD></TR><TR><TD CLASS="quote">If my car doesn't turn into a submarine, I will be at Expo VI...with a fresh engine.</TD></TR></TABLE>
glad to hear she's on track to getting back on the track carl
Old Oct 21, 2005 | 04:10 PM
tommymoose's Avatar
Default Re: (penpen)
If you say that it only happens when the car is moving, you gotta think of what is different about your car when you're driving it. Have you checked in your rear wheel-well to see if all of the rubber stuff is still intact? Maybe there is a leak in that, and when your driving, the water flings up and gets into the car somewhere.
Old Oct 21, 2005 | 04:36 PM
B18C5's Avatar
Why don't you stick someone in the trunk with a flashlight and drive around for 30kms? I'd offer to do it at Mosport but... damn I'm stuck working.
Old Oct 21, 2005 | 05:53 PM
Dogginator's Avatar
Daisy... Daisy...
I would tear the lining out and strategically place and/or tape dry paper towels to determine the entry point. It may take several rains to pinpoint the leak, but it can be found if you are systematic.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tommymoose &raquo;</TD></TR><TR><TD CLASS="quote">If you say that it only happens when the car is moving, you gotta think of what is different about your car when you're driving it. Have you checked in your rear wheel-well to see if all of the rubber stuff is still intact? Maybe there is a leak in that, and when your driving, the water flings up and gets into the car somewhere.</TD></TR></TABLE>
This is a good point.
Old Oct 22, 2005 | 11:00 AM
Holding monSteR's Avatar
Default Re: Once again, water in the hatch...search done... (Dogginator)
Based on the symptoms you seem to be experiencing, i would suggest you buy the new gaskets for the tail lights and install them. I had the exact same symptoms and bought new gaskets from acura, installed them, and i haven't gotten a drop in there since.
Thinking about your symptoms it makes sense to me that it would be the seals. Since when you are driving in the rain all the water from the roof and sides of the car is running to the tail end of the car and then off it, so alot more water would be getting to the taillights when you are moving ,as opposed to when the car is just sitting parked in the rain.
Old Oct 23, 2005 | 05:01 PM
bbqman's Avatar
Default Re: Once again, water in the hatch...search done... (Racebred H)
Thanks for all the responses. The seals are ordered and will go this week. If that doesn't cure it, I will put someone in the trunk ( probably me) and hose it down ( someone else) and see what's up.
I'll keep ya posted.
Old Oct 23, 2005 | 05:17 PM
-tc-'s Avatar
my old gsr was actullay leaking water thought the intenna hole, i never seen someone elses teg leak from here but it something to keep in mind.
Old Oct 23, 2005 | 06:48 PM
HYREV2NR's Avatar
Default Re: Once again, water in the hatch...search done... (trc_R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trc_R &raquo;</TD></TR><TR><TD CLASS="quote">my old gsr was actullay leaking water thought the intenna hole, i never seen someone elses teg leak from here but it something to keep in mind.</TD></TR></TABLE>Dang! Now thats weird.
hondatech.101
Honda Fit
Sep 6, 2019 10:34 AM
'90crxSI
12
Sep 4, 2006 03:48 PM
scyked
Apr 12, 2006 03:45 PM
idriveadelsol7
Audio / Security / Video
Apr 10, 2006 12:30 AM
Speed 101
Jan 28, 2006 06:44 PM
