acura ABS problem
Old Mar 6, 2002 | 05:35 PM
JAME CHANOBI's Avatar
Default acura ABS problem
my abs light is on for like a 2 weeks now. I dont know how to fix it. The abs light came on when i lost traction on a rainy day. before i use to burn out and made the car hop when i throw it in to 2nd and the abs light goes off. now that trick doesn't work n-e more. And the right front brake pad is cutting my rotor up. Is my brake ceased up or something.
Old Mar 6, 2002 | 09:06 PM
bearingburner's Avatar
Default Re: acura ABS problem (JAME CHANOBI)
there should be codes in the abs unit. check for that first and go from there. the most common thing are dirty abs sensors in the rear wheels and poor ground to abs pump motor. hope i have been of some help. as to the rotor thing, maybe a bad caliper or brake hose on that wheel is bad.
ramz7887
Mar 22, 2007 07:51 PM
meat
Jul 30, 2003 08:56 PM
ophdehEEzY
Mar 7, 2003 09:36 AM
Audio28
Dec 22, 2002 11:48 PM
