extedning injector wires??
Old Oct 20, 2005 | 11:28 PM
DSRxSALSA's Avatar
Default extedning injector wires??
well this is a simple one for most of you guys.. so im converting my obo-0 harness to an obd-1 for my swap. i remove and replace each injector clip one by one making sure i dont mix up the wires. i also go and extend the injector wires all deifferent lenghts. maybe 1 foot at the longest so they will be able to come up under the manifold threw the runners to the injectors.. my question is.. with extending the wires mess up the pulse width signal from the ecu??
Old Oct 21, 2005 | 12:13 AM
Expletive!'s Avatar
Default Re: extedning injector wires?? (92integGS)
Bump..cause we need to find out!
Old Oct 21, 2005 | 02:31 AM
rainforest's Avatar
Default Re: extedning injector wires?? (Slaughter)
no extending them that much wont. just use the same gauge wire.
Old Oct 21, 2005 | 06:35 AM
DSRxSALSA's Avatar
Default Re: extedning injector wires?? (rainforest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rainforest &raquo;</TD></TR><TR><TD CLASS="quote">no extending them that much wont. just use the same gauge wire.</TD></TR></TABLE>
can i get a second on this? anyone else have the same to tell me.
and yes i used the same gauge wiring
Old Oct 21, 2005 | 06:38 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92integGS &raquo;</TD></TR><TR><TD CLASS="quote">
and yes i used the same gauge wiring </TD></TR></TABLE>
sounds good. just make sure all your connections are properly soldered, and heat shunk.. dont twist **** and tape it....
Old Oct 21, 2005 | 09:59 AM
DSRxSALSA's Avatar
Default Re: extedning injector wires?? (Dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
sounds good. just make sure all your connections are properly soldered, and heat shunk.. dont twist **** and tape it....</TD></TR></TABLE>
all connections are properly soldered.. using pink heat shrink.. that only color we had at work.. lol
Old Oct 21, 2005 | 05:21 PM
DrifterzTX's Avatar
Along this same line...
Guage of wire.. what should I use? I built myself a harness for a b16a civic I have stashed away.. I'm rebuilding it. I had a bunch of wire laying around here where I work.. so I used it. What is the proper guage.. or close to?
Old Oct 22, 2005 | 08:20 AM
DaveF's Avatar
Default Re: extedning injector wires?? (DrifterzTX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrifterzTX &raquo;</TD></TR><TR><TD CLASS="quote">Along this same line...
Guage of wire.. what should I use? I built myself a harness for a b16a civic I have stashed away.. I'm rebuilding it. I had a bunch of wire laying around here where I work.. so I used it. What is the proper guage.. or close to?</TD></TR></TABLE>
i belive its 18gauge
Old Oct 22, 2005 | 01:19 PM
DrifterzTX's Avatar
how bad would it be to use 16 guage??? I had a crap load of 16 g, so I used it..
89ED
Jan 20, 2017 05:37 PM
goldex420
Sep 6, 2013 10:32 PM
boostedcivichatchbacksi
12
Oct 18, 2004 11:52 AM
shadowdawn
Sep 5, 2002 11:29 AM
EGHatchy
Jul 13, 2002 08:53 AM
