I NEED HELP!!!!!
Old Oct 20, 2005 | 10:57 PM
vietboycuhz's Avatar
Default I NEED HELP!!!!!
i have a map sensor problem.. after i got off the dyno i went home and the check engine light was on.. the car runs fine and drives normal. but here the problem. 1st gear ill pull it up to 7500-8500rpms the car is fine but when i get in to 2nd gear when i hit about 7500rpms the check light will pop on. and it feels like my fuel is cutting off like i have a limiter or something. wont let me get any higher den about 8k rpms. so i shut it off and turn it back on and the check light is off. but it throws a code 3 check engine light.(map sensor)only does it in 2nd,3rd,4th,5th. but the check engine light wont come on in first gear......
i tried changing the map sensor. but nothing ....
yes i do have a chipped ecu that goes pass 8krpms..
i changed the ecu and still nothing..
anybody that knows whats wrong would help thanks...
this car is a obd0 b series, can the cause of this be from running rich???
can a vtec controller affect this??
so my problem is check engine light only goes on when i pull it pass 7500 in 2nd gear and up.. thanks in advances if anybody knows ...
Old Oct 21, 2005 | 09:27 AM
anybody?
widewhite
Nov 20, 2014 03:49 PM
2ndGenREX
Mar 18, 2005 02:03 PM
Hatch It
Oct 25, 2004 06:15 PM
waijsR
Oct 30, 2003 01:43 AM
garados
Apr 18, 2003 06:34 PM
