Head Gasket
Old Mar 6, 2002 | 05:12 PM
str8rcn's Avatar
Default Head Gasket
I have a unique setup and was wondering if anyone could help.I have a h23 head on a h22a block.My problem is an oil leak between the head and block on the back right side of the motor under the intake cam gear.Joel at JG told me to use the h22 head gasket when he sent me my block.Also i know in crvtec conversions the ls head gasket is used so this makes sense but i still have a leak.I am planning on removing the head and having both gaskets handy for comparison but was wondering if anyone had any input.Any help would be appreciated.
Old Mar 6, 2002 | 05:16 PM
Quaalude's Avatar
Default Re: Head Gasket (str8rcn)
why did u put the h23 head on h22 block?...wouldn't h23 block and h22 head work better...gives torque of h23 but hp with vtec head
Old Mar 6, 2002 | 05:27 PM
str8rcn's Avatar
Default Re: Head Gasket (Quaalude)
Well,i didnt really mean for it to turn out that way.i spun a bearing in my h23 totally screwing up my block.I called JG and ordered a new bottom end build with them providing the block and crank.When it was finished Joel tells me that he got a h22a bottom end instead of a h23 but the blocks were the same except for an oil orifice which had to be swapped from the h23 to the h22 block.Cool no problem everything lined up and the engine runs great but has a slight oil leak so i am not progressing any further with the project intil i resolve this problem.
Old Mar 6, 2002 | 11:50 PM
G's Avatar
G
If the block had been decked by JG, the bracket below the intake manifold may cause the head to not sit properly on the block. If the block is a bit shorter than your oem (it might be since the GSR and LS blocks are different heights), it will do the same. Remove the head and remove that brace at the rear, then torque it down again. If oil still leaks, there is a surfacing problem.......
Old Mar 7, 2002 | 11:14 AM
str8rcn's Avatar
Default Re: Head Gasket (G)
Thanks ill look into that.By the way what does that bracket attach to and if i remove it what will not be attached?
Old Mar 7, 2002 | 11:31 AM
JG Luder's Avatar
if I remember correctly 2point6 told me that the oil orafice in the H23 is in the block, the H22A is in the head.
Might want to check on that.
Old Mar 7, 2002 | 12:13 PM
Greyout's Avatar
If its what I'm thinking of, there is a bracket under the intake manifold that goes from the intake manifold to the block. It is not required, you'll be ok without. (Its called a 'stay' or something like that)
Old Mar 7, 2002 | 02:32 PM
str8rcn's Avatar
Default Re: Head Gasket (JDM LUDE)
Cool.I'm going totry the bracket thing.Also i talked to a guy at OPM motorsports near Atlanta and he ran into a similar problem and said the h23 gasket fixed it.These guys race a 93si in scca not sure what class but they also manufacture camber kits and lsd's for ludes so as soon as i find out some info i'll pass it along to you guys.
Old Mar 7, 2002 | 03:32 PM
prospeed's Avatar
you have to use the h23a gasket.
Old Mar 8, 2002 | 02:41 PM
str8rcn's Avatar
Default Re: Head Gasket (prospeed)
Thanks you are the second person to tell me that.Tom at OPM motorsports told me today that the problem was the h22 gasket.Hopefully when i get a chance,with my wedding coming up,i can pull the head and fix the problem and get it into the paint shop.
Old Mar 8, 2002 | 09:10 PM
prospeed's Avatar
no prob. Good luck with the wedding and the head gasket problem!
thalwr1
Nov 7, 2014 07:35 AM
speedy108
Feb 6, 2004 10:31 AM
ludesleep
Mar 3, 2003 07:35 AM
