Which USB cable to use for datalogging?
Old Oct 20, 2005 | 07:54 PM
loudsubz's Avatar
Default Which USB cable to use for datalogging?
Is there specific ones to use when hooking up to the ECU?
There is a smsung one I saw, but it doens't seem to have the box inline on the cable that contains the circuitry like others I have seen.
Is there a specific cable to use?
thanks
Old Oct 20, 2005 | 09:25 PM
HondaTom's Avatar
Default Re: Which USB cable to use for datalogging?
I think this might be what you are looking for.
http://www.pgmfi.org/twiki/bin...gging
Old Oct 21, 2005 | 07:08 AM
loudsubz's Avatar
Default Re: Which USB cable to use for datalogging? (HondaTom)
that it is...
thank you
Old Oct 21, 2005 | 07:37 AM
drdisco69's Avatar
Default Re: Which USB cable to use for datalogging? (loudsubz)
If you're looking on ebay, get the DKU5, not the DKU2. The DKU2 is just a straight through cable, no conversion actually happens.
Old Oct 21, 2005 | 07:41 AM
loudsubz's Avatar
Default Re: Which USB cable to use for datalogging? (drdisco69)
So as long as there is a "box" inline on the USB cable that means that the circuitry is there for the TTL correct?
I see some with boxes and some are just straight cables.
Old Oct 21, 2005 | 08:04 AM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudsubz &raquo;</TD></TR><TR><TD CLASS="quote">So as long as there is a "box" inline on the USB cable that means that the circuitry is there for the TTL correct?
I see some with boxes and some are just straight cables.</TD></TR></TABLE>
Right, some of the DKU2 cables have the box, but inside is just a straight through blank circuit board, pretty stupid. So not every cable that has a box will do the conversion. And the new DKU5 cables that don't have the box have a larger USB connector with everything built inside.
Caoboy
10
Mar 12, 2015 07:32 AM
CRX 2.0V-T
Nov 13, 2005 07:05 PM
mike93eh
May 20, 2005 06:20 AM
integrator43
Honda Motorcycles
Apr 19, 2005 01:19 PM
madhatter
Dec 7, 2001 12:52 PM
