DYNO of my old N/A B16 setup.......
Old Oct 20, 2005 | 07:11 PM
Ninja Mike's Avatar
Default DYNO of my old N/A B16 setup.......
My old setup consisted of the following:
-Password JDM monster dong intake
-JDM T1R 4-2-1 header
-2.5" Kteller custom exhaust
-JDM OS P30 pistons
-Omnipower flat faced valves
-Rocket's valvetrain
-Buddy Club Spec III+ camshafts
-Tuned with Crome engine management
Take in mind, these numbers were made with:
-Stock throttle body/intake manifold
-Stock 240cc injectors
-Unported head
-99 degree F heat
Also, the compression ratio was roughly 10.8:1
Run_2 is untuned
Run_4 is tuned
At the end, cams were set to 0 since 0 made the largest power curve and peak power.
-Michael
Old Oct 20, 2005 | 07:31 PM
Turbogixxer's Avatar
Default Re: DYNO of my old N/A B16 setup....... (SleepEMike)
Old Oct 20, 2005 | 08:07 PM
89s1's Avatar
Default Re: DYNO of my old N/A B16 setup....... (Turbogixxer)
not sure what to say since i just put down 154/109 with intake and exhaust.
it was likely the crazy heat that day.
get another dyno run at 60-70*F
Old Oct 20, 2005 | 08:08 PM
boosted k20's Avatar
more power to be made from that setup. a/f looks rich
Old Oct 20, 2005 | 08:26 PM
Serdar's Avatar
Default Re: DYNO of my old N/A B16 setup....... (boosted k20)
Thats a Greatt dyno! awesome! stupendous!?
more power is to be made headwork, increase comp and maybe some Individual suckers
Old Oct 21, 2005 | 02:11 PM
SiDonny's Avatar
Default Re: DYNO of my old N/A B16 setup....... (Serdar)
nice numbers...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Serdar &raquo;</TD></TR><TR><TD CLASS="quote">Thats a Greatt dyno! awesome! stupendous!?
more power is to be made headwork, increase comp and maybe some Individual suckers </TD></TR></TABLE>
hehe... individual suckers... hhhmmmm
Old Oct 22, 2005 | 11:02 PM
0bd1_Kanobe's Avatar
If it make that kind of power with rich A/F ratios just imagine at 13:5:1!!!!!! You will also pick up some torque at higher RPM's
Old Oct 27, 2005 | 05:02 PM
Serdar's Avatar
Default Re: (0bd1_Kanobe)
yeah wish it was together so we can make some changes
Old Oct 27, 2005 | 05:29 PM
tokesGTR's Avatar
Default Re: DYNO of my old N/A B16 setup....... (89s1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">not sure what to say since i just put down 154/109 with intake and exhaust.
get another dyno run at 60-70*F</TD></TR></TABLE>
The STD correction corrects it to 60 degrees and 29.92" on the barometer, and it's pretty accurate when it comes to correcting a naturally aspirated car. STD does correct horsepower numbers higher than SAE, which is what you commonly see on here.
Old Oct 27, 2005 | 05:30 PM
Kidloco51's Avatar
Default Re: (Serdar)
4th gear pull I assume?
Old Oct 27, 2005 | 07:13 PM
blaster834's Avatar
not bad at all! hah got to love that 1.6 torque though
Old Oct 29, 2005 | 12:26 PM
Default Re: (Kidloco51)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kidloco51 &raquo;</TD></TR><TR><TD CLASS="quote">4th gear pull I assume?</TD></TR></TABLE>
yes
Old Oct 29, 2005 | 12:35 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (Turbogixxer)
why a 4th gear pull?
Old Oct 29, 2005 | 12:48 PM
Default Re: (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">why a 4th gear pull?</TD></TR></TABLE>
4th gear is the closest gear to 1:1.
ATS*Mark's Avatar
OG triple OG
ahh
Old Oct 30, 2005 | 05:01 PM
Ninja Mike's Avatar
Turbogixxer, what was the motor revved to again?
Old Jan 4, 2006 | 11:20 PM
4th gen's Avatar
Nice numbers, intrested in the cams and gears if you still have them
Old Jan 5, 2006 | 07:24 AM
Adam.'s Avatar
Default Re: DYNO of my old N/A B16 setup....... (4th gen)
Mike, i never got to see your graph, but it look slike you would've made more power revving higher, your tq curve is flat as hell at the end of the pull, revved higher would probably could've added more power.
Old Jan 5, 2006 | 08:31 AM
Kool Keith's Avatar
not bad at all
Old Jan 5, 2006 | 12:07 PM
Ninja Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4th gen &raquo;</TD></TR><TR><TD CLASS="quote">Nice numbers, intrested in the cams and gears if you still have them</TD></TR></TABLE>
I still have them indeed, check out my for sale post! PM me if you have any questions
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarkKnight1 &raquo;</TD></TR><TR><TD CLASS="quote">Mike, i never got to see your graph, but it look slike you would've made more power revving higher, your tq curve is flat as hell at the end of the pull, revved higher would probably could've added more power.</TD></TR></TABLE>
Yeah, I wish I could have revved it higher, but I didn't think the bottom end would handle it all too well.
Will the skunk2 gears that you have for sale work on my B16? If so, I'll buy them!
Old Jan 5, 2006 | 12:10 PM
Adam.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepEMike &raquo;</TD></TR><TR><TD CLASS="quote">
Will the skunk2 gears that you have for sale work on my B16? If so, I'll buy them!</TD></TR></TABLE>
Nope, h22 only.
Old Jan 5, 2006 | 12:12 PM
Ninja Mike's Avatar
Default Re: DYNO of my old N/A B16 setup....... (DarkKnight1)
Nope, h22 only.</TD></TR></TABLE>
Darn, worth asking though.. I've been in the market for a pair since October.
Old Jan 5, 2006 | 12:51 PM
Adam.'s Avatar
Darn, worth asking though.. I've been in the market for a pair since October. </TD></TR></TABLE>
What are you building up now that you need the cam gears?
Old Jan 5, 2006 | 08:20 PM
Ninja Mike's Avatar
What are you building up now that you need the cam gears?</TD></TR></TABLE>
PM sent, I'm keeping under wraps for many reasons.
Old Jan 5, 2006 | 10:27 PM
4th gen's Avatar
Can't PM yet, still NOOB! If you want email me a price at onecaprice2nv@yahoo.com
