Civic type R srut bar and GSR bar?
Old Mar 6, 2002 | 04:32 PM
mantic6t9's Avatar
Default Civic type R srut bar and GSR bar?
What is the difference between the civic typeR strut bar and the gsr bar besides the color? Is it thicker or something?
Old Mar 6, 2002 | 04:53 PM
EkREV's Avatar
New User
Default Re: Civic type R srut bar and GSR bar? (mantic6t9)
nope. same thing. only difference is the color.
Old Mar 6, 2002 | 05:15 PM
YodaIsGod
Guest
Posts: n/a
Default Re: Civic type R srut bar and GSR bar? (EkREV)
and the bar sucks....
Skunk2
Old Mar 6, 2002 | 06:32 PM
mantic6t9's Avatar
Default Re: Civic type R srut bar and GSR bar? (YodaIsGod)
Skunk2
Why does it suck. From what i've read bars that have pivot points suck the skunk2 has pivot points and aren't as effective as a solid bar with no pivot points GSR bar. HMMMM.......
[Modified by mantic6t9, 3:34 AM 3/7/2002]
Old Mar 6, 2002 | 06:37 PM
JV's Avatar
JV
Who?
Obviously you have'nt seen a real CTR front bar before.The walls of the tubing are much thicker than the SI and GSR front strut bars. I actually have both the CTR front bar and the GSR.
Maybe you've only seen the fakes they got out now, they're probably just painted GSR bars.............
Old Mar 6, 2002 | 06:42 PM
redteg1's Avatar
Default Re: Civic type R srut bar and GSR bar? (JV)
OBVIOULSY none of you know anything becuz im a big flamer!
Old Mar 6, 2002 | 07:03 PM
mantic6t9's Avatar
Default Re: Civic type R srut bar and GSR bar? (redteg1)
Well the reason i'm asking is cause i can get a GSR bar. I was wondering if it's a waste of money or if it will serve it's purpose?
Old Mar 6, 2002 | 07:24 PM
JV's Avatar
JV
Who?
It will work just fine......... Don't pay more than $20 bucks for one though........
Old Mar 6, 2002 | 08:56 PM
Downey's Avatar
which would be better? A stock ITR or the Skunk2?
Old Mar 6, 2002 | 09:00 PM
mantic6t9's Avatar
They guy i'm buying it from will go no lower then $25 shipped.
Old Mar 6, 2002 | 09:29 PM
Gump's Avatar
i agree, bars with pivot points are still good and work affectively but don't work as well as bars without pivot points
Old Mar 7, 2002 | 03:36 AM
mantic6t9's Avatar
Default Re: Civic type R srut bar and GSR bar? (xlr8 si)
Anyone know what all i'll need to mount this bar to my 93 hatch?
Old Mar 7, 2002 | 04:12 AM
JV's Avatar
JV
Who?
$25 shipped is good........
Do you already have the holes in the strut towers? If you do you'll just need some
bolts to install it...........
Old Mar 7, 2002 | 07:53 AM
JDM CRX's Avatar
Just go with a NeuSpeed Strut Bar they are all one piece strong as schiznitz and no pivots. Just my 2 bucks
Chicago Mike
Old Mar 7, 2002 | 08:33 AM
killingtime's Avatar
Simple Green and low pressure water
Old Mar 7, 2002 | 08:34 AM
kefka's Avatar
Default Re: Civic type R srut bar and GSR bar? (JDM CRX)
Chicago Mike
hell yea i am running a beuspeed and that bar kicks ***,i wish sat a little lower so i could use both a gsr and the neuspeed...
Old Mar 7, 2002 | 10:24 AM
VoltageLS's Avatar
New User
Default Re: Civic type R srut bar and GSR bar? (madeinjapan)
I too can vouch for Neuspeed...4 mounting points, no pivots either. All that goodness for what, $95?! Can't beat that at all.
Old Mar 7, 2002 | 01:29 PM
mantic6t9's Avatar
Default Re: Civic type R srut bar and GSR bar? (VoltageLS)
That was going to be my nexr question. Yeah my hatch already has the holes. Anyone know what size bolts i need?
Old Mar 7, 2002 | 01:33 PM
YodaIsGod
Guest
Posts: n/a
Default Re: Civic type R srut bar and GSR bar? (killingtime)
that pic a about a year old...i've cleaned it since then...oh well....
Old Mar 7, 2002 | 03:22 PM
mantic6t9's Avatar
Come on, someone has to know what i'll need to install the gsr bar in my 93 hatch. It already has the holes. Who here has done it?
Old Mar 7, 2002 | 03:26 PM
JV's Avatar
JV
Who?
I used some 3/8" grade 8 bolts w/ lock washers and 3/8 nuts..........
Old Mar 7, 2002 | 03:28 PM
Stop the Beast's Avatar
Try using 12mm bolts with lock washers. I too can vouch for a Neuspeed 4-point. I've used several pivot point bars and the 4-point blew them away.
Old Mar 7, 2002 | 03:35 PM
Civic VTi's Avatar
If Yoda were god, he'd tell you to CLEAN YOUR ENGINE BAY!
Old Mar 7, 2002 | 03:49 PM
mantic6t9's Avatar
Default Re: Civic type R srut bar and GSR bar? (Civic VTi)
ok thanks. What size are the bolt on the integra? Should i run the bolt through the bottom of the fender and put the washer and nut on top or the other way around?
Old Mar 7, 2002 | 08:11 PM
mantic6t9's Avatar
Anyone?
