Civic type R srut bar and GSR bar?
Re: Civic type R srut bar and GSR bar? (YodaIsGod)
and the bar sucks....
Skunk2
Skunk2
[Modified by mantic6t9, 3:34 AM 3/7/2002]
Re: Civic type R srut bar and GSR bar? (EkREV)
nope. same thing. only difference is the color.
Maybe you've only seen the fakes they got out now, they're probably just painted GSR bars.............
Re: Civic type R srut bar and GSR bar? (redteg1)
Well the reason i'm asking is cause i can get a GSR bar. I was wondering if it's a waste of money or if it will serve it's purpose?
Re: Civic type R srut bar and GSR bar? (JV)
It will work just fine......... Don't pay more than $20 bucks for one though........
Re: Civic type R srut bar and GSR bar? (mantic6t9)
Why does it suck. From what i've read bars that have pivot points suck the skunk2 has pivot points and aren't as effective as a solid bar with no pivot points GSR bar. HMMMM.......
They guy i'm buying it from will go no lower then $25 shipped.
Do you already have the holes in the strut towers? If you do you'll just need some
bolts to install it...........
Just go with a NeuSpeed Strut Bar they are all one piece strong as schiznitz and no pivots. Just my 2 bucks
Chicago Mike
Chicago Mike
Re: Civic type R srut bar and GSR bar? (JDM CRX)
Chicago Mike
Chicago Mike
New User
Re: Civic type R srut bar and GSR bar? (madeinjapan)
I too can vouch for Neuspeed...4 mounting points, no pivots either. All that goodness for what, $95?! Can't beat that at all.
Re: Civic type R srut bar and GSR bar? (VoltageLS)
That was going to be my nexr question. Yeah my hatch already has the holes. Anyone know what size bolts i need?
Come on, someone has to know what i'll need to install the gsr bar in my 93 hatch. It already has the holes. Who here has done it?
Try using 12mm bolts with lock washers. I too can vouch for a Neuspeed 4-point. I've used several pivot point bars and the 4-point blew them away.
Re: Civic type R srut bar and GSR bar? (Civic VTi)
ok thanks. What size are the bolt on the integra? Should i run the bolt through the bottom of the fender and put the washer and nut on top or the other way around?
