TSX FD in k20a2 tranny
Old Oct 20, 2005 | 04:52 PM
LSVtecEK1's Avatar
Default TSX FD in k20a2 tranny
Does anyone know if i can use the countershaft from a TSX or 05 RSX with the final drive gear from a 03 SI? thanks in advance.
Old Oct 21, 2005 | 12:29 AM
LSVtecEK1's Avatar
Default Re: TSX FD in k20a2 tranny (LSVtecEK1)
DAMN, 27 VIEWS AND NO ONE KNOWS? TO THE TO FOR SOME HELP PLEASE.
Old Oct 21, 2005 | 07:04 AM
BarracksSi's Avatar
I think it might work -- I wish I had the issue of Honda Tuning that talked about swapping tranny internals.
FWIW, the 05 RSX already has the same final drive ratio as the Si (either the EP3 or the FG2 Si's, for that matter).
Old Oct 21, 2005 | 09:44 AM
LSVtecEK1's Avatar
Default Re: (BarracksSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BarracksSi &raquo;</TD></TR><TR><TD CLASS="quote">I think it might work -- I wish I had the issue of Honda Tuning that talked about swapping tranny internals.
FWIW, the 05 RSX already has the same final drive ratio as the Si (either the EP3 or the FG2 Si's, for that matter).</TD></TR></TABLE>
thanks, i know the final drive ratios are the same but a frined of mine only has the countershaft from a tsx and i was just going to get the gear from someone else, but its from a ep3.
Old Oct 22, 2005 | 04:00 AM
LSVtecEK1's Avatar
Default Re: (LSVtecEK1)
anyone?
Old Oct 22, 2005 | 10:07 AM
George Knighton's Avatar
H-T Order of Merit
I'm sorry, but I really do not know.
I know that the transmission from the CL7/CL9 is really very different from the transmissions in the EP3 and DC5.
I also know that almost all parts between the EP3 and DC5 transmissions are interchangeable. You can exchange the different final drives, the Torsen diffs, and even add the DC5 sixth gear to the EP3 transmission.
I also happen to know that the transmission from a CL7/CL9 will not even fit under the DC5 or EP3.
Old Oct 25, 2005 | 12:01 AM
LSVtecEK1's Avatar
Default Re: (George Knighton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton &raquo;</TD></TR><TR><TD CLASS="quote">I'm sorry, but I really do not know.
I also happen to know that the transmission from a CL7/CL9 will not even fit under the DC5 or EP3.</TD></TR></TABLE>
Thanks, i guess im just going to put them both together and count the teeth and see if it will work or not. I'll post it up after i get some results.
Old Oct 25, 2005 | 02:26 PM
f1nal zeros's Avatar
Why not just get the final drive and shaft from a 05 rsx-s (same as DC5R) and install in your car. Thats what I'm doing..
Old Oct 25, 2005 | 02:58 PM
BarracksSi's Avatar
He's already got the countershaft and can get the EP's FD gear, he's just asking if they'll actually fit.
Old Oct 25, 2005 | 09:33 PM
LSVtecEK1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BarracksSi &raquo;</TD></TR><TR><TD CLASS="quote">He's already got the countershaft and can get the EP's FD gear, he's just asking if they'll actually fit.</TD></TR></TABLE>
Thanks for actually reading my post, unlike most people. I just want to know if anyone knows for sure if the ep3 gear will work with a tsx counter shaft.
Skunk91
May 5, 2006 06:58 PM
efyou
17
Apr 13, 2006 10:37 AM
lilrabidmonkey
Sep 1, 2004 06:28 PM
K20EG
Oct 5, 2003 01:45 PM
ArcticFreeze
Feb 19, 2002 10:59 AM
