low after market gearing
Old Oct 20, 2005 | 03:26 PM
low gearing's Avatar
Default low after market gearing
Hi Guys, I am new and thank your for accepting me.
Recently, I asked ATS to see if they got 4.92 diff for my 1990 LS b18a cable integra. They said no. Unless I ordered more than 50.
So I appreciate if any knows that I can get aftermarket low gearing?
Thanks
Old Oct 20, 2005 | 03:45 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: low after market gearing (low gearing)
You must mean high gearing, right? Or short gearing.
Check out http://www.gearspeedinc.com/
They might have something. He is also a member on this site. His username is "GearSpeedEF7"
Old Oct 20, 2005 | 04:29 PM
Default Re: low after market gearing (shamoo)
I mean short gearing for better accleration...
thanks. I will check the site right now
Old Oct 20, 2005 | 04:31 PM
no luck, its currently under"construction"....
Old Oct 20, 2005 | 04:37 PM
Moogen Powah's Avatar
Aside from changing the FD, have you considered swapping transmissions?
Old Oct 20, 2005 | 04:44 PM
Default Re: low after market gearing (Moogen Powah)
GOOD THINKING..... SO ALL B SERIES ARE INTERCHAGEABLE??pEOLE TELLS ME YES AND NO.....REALLY STUFF ME UP.
i WILL LOOK UP YOUR SITE NOW.
thank you
Old Oct 20, 2005 | 04:48 PM
95lstegman's Avatar
1) convert from cable to hydro. gear choices are much larger. you could use B16/ITR gears with either 4.785 or even 4.9 ATS FD. that's GOTTA be short enough for you.
2) keep your stock brakes, and get some 14" wheels and order up some 40-series tires. a 195/40R14 tire would lower your gear ratios the same amount as going from your stock 4.40 final drive to a final drive of ~4.97. so just get some super low profile tires and you'd be set. and besides, this option saves you tons of work and CRAPLOADS of money. no cable to hydro conversion, no hydro transmission to buy, no $900 ATS gears to buy, etc.
dirtyharryhatch
Jul 8, 2008 05:08 PM
Ls_dx
Jun 28, 2006 08:37 AM
95lscivic
Aug 16, 2005 06:54 PM
11secEk
Mar 22, 2005 09:34 PM
91civicDXdude
15
Jun 2, 2004 06:35 PM
