What ecu to use...
I have a 4ws 92 lude automatic. I just got a f22b motor because my H23a got fried. Anyway I was wondering what ecu to use... because I heard that the H23A will have a lower redline then the engine can handle, and the F22b one has a speed limiter on it?! Either way I dont know much So I thought id ask
Thank you for any inputer
B.
B.
you got lots of options.
you can run a p14 which is the h23 ecu which you should still have. You can run a p74/p75 (92-95 OBDI Integra LS/GS), have it socketed then get a basemapped chip, take it to a dyno and tune it on hondata, crome, uberdata, etc.
there's plenty of other ecu's you could run. But if you dont want to get into ttuning and all, i would just run the p14 that you should still have in the car now. the f22b is basically the same motor as the h23.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">...i would just run the p14 that you should still have in the car now...
you could also use a p12. i would just use the p14 tho
SUB-0 H23
Dec 30, 2004 09:41 AM
