which helicoil for 10x30 bolt?
Old Oct 20, 2005 | 12:06 PM
00TypeR's Avatar
Default which helicoil for 10x30 bolt?
searched and cant find it so im asking. which helicoil for a 10x30 bolt. one of the lower torque mount bolts into the body is stripped and i need to put a helicoil in it or tap it. the closest i found online wasa 10x20. what do you guys think?
Old Oct 20, 2005 | 12:52 PM
D's Avatar
D
Default Re: which helicoil for 10x30 bolt? (00TypeR)
2X thread diameter is more than sufficient. honda probably just has a captive nut on the other side of the sheetmetal anyway. Metric helicoils are not the easiest to come by (nor cheap), especially in the non as common 1.25 pitch. where are you purchasing?
Old Oct 21, 2005 | 11:09 AM
00TypeR's Avatar
dont know where im gonna get it from. still figuring out what and how to fix it.
Old Oct 21, 2005 | 02:41 PM
DC2 to AP2's Avatar
Default Re: (00TypeR)
i think the most effect and easiest way would be to timesert the hole which is alot stronger then heli-coil.
germanturtle
Nov 13, 2011 07:42 PM
Nbboy7
Jun 24, 2008 02:36 PM
gpilethbridge
Apr 4, 2007 01:41 PM
projectPSI
Jan 31, 2006 06:36 PM
gowyeng
Jun 20, 2004 12:02 AM
