who has experiance installing arp headstuds without removing the head? jdm d15b
I remember reading a while back that a few members installing arp headstuds without removing the head. for those who did, how is your car running now? and what method did you use to install the studs? this is for a 95 civic ex with jdm d15b. thanks in advance
There are only 2 reasons why someone would want to add head studs to their motor.
1.) Their head has lifted and their head gasket is blown.
2.) They want to prevent 1.)
If you are #1 then you need remove the head anyways to replace the head gasket. If you are #2 then by replacing the head bolts with studs WITHOUT REMOVING THE HEAD will compromise your head gasket integrity and turn you into #1.
Dont ghetto it. Do it right.
DelSol-B18
Sep 8, 2012 06:24 PM
EJ1 wilcox
Feb 23, 2006 03:08 PM
