--Neuspeed Sport Springs-trim bump stops?--
Old Oct 20, 2005 | 11:24 AM
Arsenal's Avatar
Default --Neuspeed Sport Springs-trim bump stops?--
Just received my new neuspeed sport springs.
However, it says not to trim the bumpstops, but I have searched on here and lots of people have.
So if you did or did not please shead some light, thanks
Old Oct 20, 2005 | 12:53 PM
shyboi4u's Avatar
Default Re: --Neuspeed Sport Springs-trim bump stops?-- (Arsenal)
it said the same thing for the accord. i didn't cut the bumpstop. some ppl say cut them if you want more shock travel and i heard don't cut them because the springs work with bumpstop.
Old Oct 20, 2005 | 01:10 PM
ekcivic9's Avatar
the struts/shocks should come with bumpstops?
are you guys running oem shocks?
Old Oct 20, 2005 | 01:28 PM
Slow EJ8's Avatar
In for the answer as i was considering these springs.
Old Oct 20, 2005 | 03:24 PM
Civicse's Avatar
Default Re: --Neuspeed Sport Springs-trim bump stops?-- (Slow EJ8)
its only a 1.75 - 1.5 drop right? so no u don't have to cut them
Old Oct 20, 2005 | 04:00 PM
Arsenal's Avatar
Default Re: --Neuspeed Sport Springs-trim bump stops?-- (Civicse)
If I cut them will the car sit lower?
Old Oct 20, 2005 | 04:02 PM
ekcivic9's Avatar
you will get more shock travel, but i dont know about sitting lower.
did you get aftermarket shocks/struts?
Old Oct 20, 2005 | 04:07 PM
Civicse's Avatar
Default Re: (ekcivic9)
your car won't sit lower. the springs determine how low your car sits, but if u cut your bump stops if you go over a big bump when the car bounces the shocks will allow your car to go further when it comes down, now if you had like a 2.5 inch drop or lower and u kept the bump stops whole, you would prolly bottom out your shocks so you would need to cut them to allow the shocks to travel further down
Old Oct 20, 2005 | 04:35 PM
Arsenal's Avatar
Default Re: (Civicse)
They are still OEM shocks, I have Koni's coming but it will be awhile, just tired of looking at a huge wheel gap!
Well I will leave them for now and see how it goes.
Thanks
citizen21
Suspension & Brakes
Oct 21, 2008 01:26 PM
SwiftTypeR
Apr 9, 2007 10:38 PM
vtec lude3
Oct 5, 2004 03:38 PM
alex01
Aug 23, 2004 12:53 PM
EGO
Jun 11, 2003 11:27 AM
